How fat of a rear tire will fit WDs? |
OrangePowerGA
Topic: How fat of a rear tire will fit WDs?Posted: 05 Apr 2010 at 10:38am |
I've got a rear tire that is totally shot with a huge tear in the sidewall.
What is the widest rear tire that will fit a WD without rubbing the fenders? Also, any recommedation on a tire that pulls good?
Thanks in advance...with any luck I hope to have it running again asap.
John (C-IL)
Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Posted: 05 Apr 2010 at 4:06pm |
I've got 18.4 x 26 on one. If you spun the wheels out or had a deep offset you could go wider. The only problem you will have is wheel width, but you could go 20.5 if you had the right wheel combination.
I'm not sure what size these are, but they are MONSTERS!
Edited by John (C-IL) - 05 Apr 2010 at 4:10pm |
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 05 Apr 2010 at 4:18pm |
Mine has 14.9's on it
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1006 |
Posted: 05 Apr 2010 at 6:54pm |
We,ve got 16.9's on 14" rims pulls good.. We've also had 16.9's on a 13" rim and it would'nt pull itself off the trailer.. Like John (C-IL) said, it depends on your rims.
