How fast dose a wd-45 go?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: How fast dose a wd-45 go?
    Posted: 11 Feb 2011 at 6:17pm
Tractordata says 11.5mph is this true?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 6:20pm
   Mine will do a 1/2 mile in 2 Mins. = 15 mph
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 6:24pm
11.5 to maybe 12 MPH at 1400 RPM (rated speed of the engine) but high idle no-load is 1700 rpm which is closer to 15 mph.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 7:14pm
That seems right with the exception of one of my WD45s that only had one governor weight and would go close to 20 mph.  (17-18 mph to be more precise)
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 12:56am
With 15.5-38s and an engine running 2300 rpm I can get 25mph out of mine!! I wouldnt recomend it tho, it can get a little scary with a loose front end.
kj@junction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kj@junction Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 1:29am
mine has 18.4 x26's and will do alittle over 16
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 1:55am
We could all pitch in and rent the Indy raceway and run a 500 mile race, with an average speed 0f 18 while on the track, and figuring stopping for fuel and potty breaks, we could run the race in just a little over 30 hours!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:08am
Mine will go 100 miles a day--- done it!
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:14am
Mine will do 15 mph with a stock governor and 14.9x28.  My WD is the racing machine, it will do 17-18mph with 13.6x28 and a 170 governor spring.
