How do these specs look
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: How do these specs look
    Posted: 06 Jan 2018 at 7:46pm
How do these cam specs look, battling a lopey idle and wondering if its cam related
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 8:55am
is it something you have been battling or recently installed cam and now have trouble.  could be a fuel ratio issue at idle with more lift?
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 11:08am
Is the cam lift I320E370 ??
Edited by Morten.have - 08 Jan 2018 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:23pm
It's an A-C 175 gas grind. I sent Berry cam a new 175 camshaft some 25 plus years ago and they copied the cam lobe profile and have re-ground 100's of them to this spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 5:59pm
It started after cam install. Hard to tell if its fuel or cam issue. 240 ci engine made 39 hp with stock cam and cracked manifold so I upgraded it to a tax 464 and new manifold. Should have plenty of fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 4:53pm
A "175" cam grind will idle just as nice as a stock cam grind. No difference in idle quality unless you're 1 tooth off in gear mesh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:52pm
Ok will mess with the carb some more
Would being 1 tooth off hurt horsepower? Was expecting more than 38 bp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 3:59pm
38 HP on a what model??    A "WD" was 34 HP stock. A "WD" with a 175 cam might only be 38 or 39 HP. If you didn't dyno the tractor before and after the camshaft change with the same dyno and same air temperature, how would you know how much HP you gained  ????
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 5:17pm
If you don't have the compression of the 175 then a 175 cam probably knocked the compression down a tad and cuts power
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 5:49pm
Will the toning marks be the same from a wd to a wd45? We sent a 45 cam to be ground . We used the cam and gear in a regular wd front gear set
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:09am
Timing marks are the same. You didn't answer the question.........how many HP did it have BEFORE you made the camshaft swap??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 5:30pm
Not a clue, it was rebuilt due to being an oil burner with low compression. It would run out of power in the 4000 pound stock class if the track was grippy. It got a cam 45 crank and 1/8 inch overbore kit
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 7:34am
Wish I would've found Berry's when I rebuilt my 45 last year. I'd checked around a little, but didn't find anyone that seemed reliable and would actually make the correct grind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 9:17am
Well, with 4 1/8" pistons on a WD-45 crankshaft, one should expect 50 HP or more. BUT, the only way that will happen, is if it has COMPRESSION.  A WD-45 should have 125 lbs cranking compression and a D-17 has 145 Lbs.  RUN A CRANKING COMPRESSION TEST ON THIS ENGINE WITH ALL 4 SPARK PLUGS REMOVED AND A BATTERY CHARGER CONNECTED AND THROTTLE WIDE OPEN.  If it only has 100 lbs of compression, that is your problem. Poor quality pistons and sleeves...... seen it before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 12:54pm
An improperly degreed installation of the camshaft will also give poor quality results. If building a pulling motor, you don’t just install parts and hope for the best. I don’t work on the W_ engines, however I’ve never seen a reground cam that will install properly without some tweeking.
Edited by PaulB - 12 Jan 2018 at 12:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 2:50pm
This camshaft grind is the same as a stock A-C 175 gas tractor engine. It needs no tweaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 3:59pm
Until there is an actual, accurate compression test performed, everything is speculation. The engine has to have good compression to make HP. This is where to start.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 6:25pm
I think you have the wrong one , ha drallis then we built ours 4 .5 bores I did not have that much duration at 50 I am at 200, Berry has two different 175 grinds he has yours (the dotors, stock) and a hot 175 for high rpms the special, I recall when scott made pattern of 175 stock cam,but I do not know if you all know that Scott died about 5-6 years ago , one of his helpers at time is running the place ,does not know specs  and how they work nor do I ,I had him do some cams for me and way to big no horsepower ,so I had a stock 175  casting number 249470  and took back to him to see what one was right , we did find drallis notes and stock 175 grinding specs cam should have pointy lobes not long flats or rounded I think we put the casting number by the grind you want call if I can help I am 50 miles from Berrys and can take my 175 cam back if needed  507 766 0551
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 6:41pm
Yes, a stock 175 grind has the lobe peaks very sharp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 7:15pm
Unless the person set the cam core into the grinding machine 100% correct the centerline is bound to be off at least a few degrees. Also if I’ve completly followed this thread correctly the camshaft that was reground was a WD45 cam not a 175, so the specs are out of whack to begin with, so my take is that checking the cam lobe centrlines is the first item needed to diagnose the problem.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 9:21am
the cam card looks to me like an awfully long duration and high lift for being patterned after anything from the factory. 238* @ .050" is a lot of duration, and probably why it has no compression like Dr is trying to point out. Also, .480" valve lift? That is pretty huge llift numbers too. I'm betting this is the high rpm version they created from the 175 cam initially.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 9:51am
I live about 30 miles from Berrys and locally he does not have a very good reputation. Have talked to several former unhappy customers, I wouldn't bring work there.
Edited by NEVER green - 13 Jan 2018 at 9:52am
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 6:13pm
With 238* of duration @ .050 lift on a siamesed port 4 cylinder you have 3 valves open for a long time connecting 2 cylinders.  The engine will run like a sick air compressor.....In simple terms, it's not going to work.
FOr any of these siamesed port 4 cyl engines in a low speed application, meaning 2500 RPM and less with a typical torque band of say 1800 down to 1200 RPM you can use the following examples.  A typical camshaft duration for an engine like this at .050" is going to be 176* for most of the stock camshafts.  A pulling camshaft for a smaller displacement engine is going to be in the 195* area, a mid sized engine or a larger displacement engine running with a little speed would be in the 215* range.   A very large engine or one that is going to run very fast will be in the 224* area, any more than that and there's simply to much overlap.
People like to throw the term "175 grind" around because every beginning engine guru is a camshaft expert.  I've had people bring me camshafts to install because they had it ground to this magic spec and the card read like the one you posted a picture of.  It's scrap metal.  I know it's not what you want to hear, I'm sorry but stay away from Berry cam service.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 8:08pm
The only 175 gas camshaft specs in the A-C service manual are the following: Cam lift at cam lobe .312" to .318"........rocker arm ratio of 1.488 to 1........  Intake valve lift .461" @ .012" valve lash.......Exhaust valve lift .458" @ .012" valve lash.....intake is open 220 degrees of rotation (2 degrees BTDC to 48 degrees ABDC)....exhaust is open 230 degrees ( 37 degrees BBDC to 12 degrees ATDC)
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 8:18pm
I So where do you go to get a good cam for work and or pulling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 7:40pm
Yes where is a good place to get a camshaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 8:14pm
I think Steve Fischer can help you out and Berry needs to grind you another cam to the real 175 spec for free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 8:09am
that's disappointing.  I had a cam ground for a wc puller and provided rpm, cubes, etc for custom grind,  perhaps I should check the card as its not installed yet.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 9:49am
By the service manual specs if the tractor model 175 intake duration is 220* at .012 lift that would equal about (not exactly) 185* at .050. The exhaust duration per the AC service manual is 230* at .012 lift which would equal about (not exactly) 195* at .050. The lobe separation angle would be another important number which could be calculated by the numbers given.
Your 240*  @ .050 lift cam sounds way big.
Edited by O.P.S. Heads - 15 Jan 2018 at 9:52am
