how do i tighten tracks |
rkbrkb
Joined: 07 Dec 2012 Location: redwater tx Points: 2 |
Topic: how do i tighten tracksPosted: 07 Dec 2012 at 6:11pm |
I HAVE A HD5G19311 TRACK LOADER WITH A BACK HOE ON THE REAR. I HAVE A TRACK THAT IS LOOSE AND WOULD LIKE SOME ADVISE ON HOW TIGHTEN THE TRACK.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42202 |
Posted: 07 Dec 2012 at 7:49pm |
The track adjuster is a threaded piece that sets parallel to the truck frame. On front end is a clamp with 2 bolts that go into front idler bracket, loosen these 2 bolts to allow movement of threaded portion of adjuster , lube threads with penatrant and then with large wrench turn adjuster out to tighten chain.
If it has been a long time since it has been adjusted it may be frozen and heat will need to be applied. If this still does not work as a temporary fix you can shim the idler at end of the yoke or at cop end that sets on spring . Next is to split the track remove the full adjusting yoke and repair or loosen off the machine - then replace .
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 09 Dec 2012 at 4:50pm |
Also remember the tracks on a dozer are not supposed to be totaly tight there should be some droop in the top of the track.
