Hough H30 Payloader
Message Reverse Sort Order
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Hough H30 Payloader
    Posted: 07 Jun 2018 at 5:58pm
Well said Coke and very true.
I have a Bobcat Skidsteer model 863 turbo. 75 HP. Has lift capacity of about 2100 pounds. I have taken good size tree stumps out but never try ramming them out. Treat them like pulling a tooth. If I am cutting down the tree I leave a 5' tall stump for leverage. Work all around the stump till it starts to move. Then you know know ya got it on the run.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 9:36am
Taking out stumps is not a brute force endeavor - it's feness and figuring how to do it !
You might do a 2" easily with one swipe of bucket but larger require digging around edges . Practice with it before trying to ram or attack them straight on .
Same with piles - don't attack them straight on but start on edge and work into them, shearing the material off rather than trying to move the full thing at once. A partial bucket of hard material takes power , a full bucket of losend material takes knowledge
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 11:42pm
First loader I rain as a kid was a Hough 120, for many years. With a straight pipe. Coolest thing ever. She still going to this day
Yooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yooper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 10:18pm
Hey Scott, I am looking at possibly purchasing the same hough h30 payloader for the farm. I am curious how it worked out for you ripping up those stumps of yours? I am going to use it to move black dirt and push up a lot of tree stumps, but I’m not sure if it’s big enough to dig up stumps. Also if you know the specs on it that would be great. I can’t find much about these things on the internet. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 10:21am
Those are good tough machines , should work well for stumps start low , lift as you go to keep traction , you may try Ebay for that manual , or it should be avaliable thry CNH ???
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 9:28am
Another question...Where might one find a repair manual for this machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 8:54am
I was practically given this Payloader last week. It runs and functions but acts like it has fuel system gremlins. I intend to pick up all the rock piles on the edges of my place and "install" them as backfill on a culvert out back this summer. Curious as to the effectiveness of a machine like this at destumping. Stumps vary from 2" little ones to maybe up to a few 18" across. There are far more 2 -10 inch stumps than big ones. I also got a set of forks with it, the guy I got it from used it to put junk cars onto his scrap trailer. Anybody else here have one like it? Thoughts?
