Horses, Ponies, Mules, and Donkeys
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Horses, Ponies, Mules, and Donkeys
    Posted: 06 Jul 2025 at 2:11am
Hall Valley Road Trip
KY Hwy 80 East - Russell Springs - Russell County - Kentucky
Photo Taken through the Glass of a Moving Vehicle
Saturday_26-April-2014
Horses behind Bill Bailey's Horse Barn
If you will look close, you can just see the legs of a foal standing on the other side of the Cremello.
South side of KY80 in the narrow strip between KY80 and The Cumberland Parkway
37.071084°N  85.034793°W  328.2696 m  1,077'
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2025 at 1:09pm
Field of Horses
South side of KY80
37.084197°N  85.011889°W  320.3448 m  1,051'
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 3:19pm
KY Hwy 80 East - Windsor - Casey County - Kentucky
A Cremello Horse on the Ricky Owens farm.
A Black, a Buckskin, and a Cremello
A Sorrel and a Buckskin
North side of KY80
37.129848°N  84.890216°W  Elevation 1,158'
Ten years later, in July-2024 Street View, all these white fences are black.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 4:35pm
Gees Buckskin, I saw the post title and thought you had met my inlaws
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 6:00am
Horses - A Dun and Two Buckskins
I first declared that Dun Horse to be a Bay; however, the more I looked at him, the more I wanted to label him as a Dun.
True Dun horses are rare; however, considering the prevalence of Cremello and Buckskin horses on this property, it is highly likely that he truly is a Dun.
A Crude-oil tank is in the background; look at July-2024 Street View to see how they have improved the situation of the big tank; I wish we had one on our place.
When you drive past this place, the crude is so thick in the air that you can wipe it off your lips.
North side of KY80
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 10:08am
A Cremello Horse
In the background is an oil-well pump-jack like HERE.
North side of KY80
37.129434°N  84.889195°W  Elevation 1,153'
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2025 at 2:50pm
A Buckskin Horse
In the background is an oil-well pump-jack.
North side of KY80
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 7:57pm
North Flatwoods Road - Nancy - Pulaski County - Kentucky
Two Horses - A Buckskin and a Sorrel
That is not a steel fence post, but a road sign post serving duty as a fence post.
East corner of KY80 and Flatwoods Road
37.127070°N  84.878068°W  Elevation 1,138'
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 7:20am
The Red Roan
This one is carrying the Roan to an extreme.
This is the BEFORE version:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 4:32pm
A Black Paint Horse
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 5:09pm
A Shaggy Pony
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2025 at 11:00am
Mule-driven Cane Mill
As Seen at Renfro Valley Appalachian Harvest Festival__2006
This mule is turning the gears within a sorghum cane mill, often called a molasses mill.
The mule walks in a circle, pulling the big pole that is behind him.
The slender spring-pole behind the boy's shoulders is fastened via a lead-rope to the mule's bridle and keeps slight constant pressure on the bridle and thus  leads the mule.
In this shot, the mule's bridle is not yet hooked to the spring-pole.
Note the muddy circular trail where the mule walks the circle, thus turning the mill.
It does not have to rain for it to be muddy at Renfro Valley; the whole place sits on spongy swampy-natured ground; the slightest shower can turn it into a quagmire.
Note the arm-load of cane stalks on the ground directly under the big pole.
Also note the load of cane stalks on the trailer in the background.
As the mule walks in a circle, turning the mill, the cane stalks are fed through the mill where it squeezes the juice from the stalks.
The juice is captured and later boiled off into molasses and either eaten as-is or eventually processed into sugar.
Notice the expensive-looking camera hanging on the Amish lady's neck.
The bits and pieces of green stalks under the wagon are cane stalks that have already passed through the mill.
Under the shed in the right background is the boiling tray, hence the smoke-stack and the big pile of fire-wood.
The cane juice from the mule-driven mill is put in the boiling tray where it proceeds through various skimmers and processes, until it is boiled into molasses.
Note the team of mules and wagon full of passengers in the left background.
Visible between the rear wheel and the big pole is the slender spring-pole (with the green lead-rope); the spring-pole is fastened via the lead-rope to the mule's bridle and keeps slight constant pressure on the bridle and thus  leads the mule.
In the center back-ground, notice the pair of mules pulling a wagon-load of passengers.
US Hwy 25 - Renfro Valley - Rockcastle County - Kentucky
I-75 Exit #62
Saturday_07-October-2006
37° 23' 1.07"N  84° 19' 43.12"W  Elevation 928'
This page was generated in 0.152 seconds.
