Hood Latches
JeremyHarmon(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeremyHarmon(VA) Quote  Post ReplyReply Direct Link To This Post Topic: Hood Latches
    Posted: 13 May 2010 at 8:48pm
I am looking for some hood latches for a D10II.  Others D-series latches will probably work as well.  Thanks, Jeremy Harmon. jjharmon@vt.edu
6080-3500hrs   CA NF 618GT
5050-2300hrs   78 Hay Rake
5050-1100hrs   Snap Coupler Equip
5040/loader-2800hrs   CA WF
D12III   D10II   B112
JohnBNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnBNY Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:43am
When I was searching for latches for my D10, I discovered that the same exact latch was used on steel military ammo boxes( the canvas handle older ones wwII era). I found one at a garage sale and the other ones on ebay by searching ammo boxes. I had no luck any where else, and these are exact.
Brad VB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad VB Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:45am
I got one for my D-17 off a salvage gleaner combine
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 9:38am
I thought that I had read on here that somebody saw them at Mcmaster-Carr.
1961 H3
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 5:02pm
Which ones are you looking for as they used different one on the D series. I have one latch in stock which has the 1/2" wide blade with the bent hook on the end, I have a supplier sending me samples for the one with the oval end with a slot that fits the D14 and a quote for this same type that has a longer blade length that fits the D15. Don't have a series II here to see what you need. Can you send me a picture?
went to local AGCO dealer and they and AGCO did not have any......Had them do a nation wide dealer search and nothing showed up.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 6:31am
Both types of D series hood latches are still available. I can buy them at a local industrial fastner supplier. I sell new roller mills that have the exact same latch on the guards. Send me a PM and I'll look up the info.
