HONDA - Class 8 truck fuel cell |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42018 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jun 2024 at 1:02pm |
https://www.truckinginfo.com/10223405/honda-debuts-class-8-hydrogen-truck?utm_source=newsletter&utm_medium=email&utm_campaign=20240621_1705:66704a6f5f9f71371f082148:ot_NL-HDT-EquipmentReport-20240619&omid=1009689398&cid=6346623e539111e4c30259cd
https://youtu.be/sL_Y3ShEUyk?si=BFZY8XOSX6Oo1MLg Honda is using a fuel cell on their truck while others are modifying Diesel engines to burn hydrogen . |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88426 |
WHERE do they propose to get the HYDROGEN ?? YEP.. thats what i want... a truck rolling down the highway at 80 MPH with a 10,000 PSI tank fill full of HYDROGEN !! ..... Can you say HYDROGEN BOMB ??
Seems Iceland has switched much of public transportation and public owned vehicles over to Hydrogen as main fuel source , so it's being used on daily basis .
Not much said about electric charging and lithium battery fires , or the weight and range from vehicles so equipped . The full EV fiasco reminds me of the CFL lightbulb idea , YOU must change over all your bulbs to CFL to save the planet . EXCEPT call a Has Mat team if you break one as they contain Mercury and other harmful thigs . They don't work in cold , and the life is rated at 3 hours or less use per day . |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
Hydrogen ? The Earth has a nearly ENDLESS supply !! Simply put two electrodes into a pail of water, and put power to the electrodes. one make Oxygen, the other hydrogen. EASY OK, to POWER the system, connect a few windmills and solar panels There you go...... totally FREE energy !!!!
hmm.. glanced at the 'specs'.... WHY does a 'hydrogen powered ' truck need a 120KW high voltage battery ? Wonder how much heavier the truck weighs ? What's it cost to tow it when the fuel runs out ?
Simply put two electrodes into a pail of water, and put power to the electrodes. YEP... put $2. of POWER IN and get $1. of Hydrogen out... NOTHING is "FREE"..
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9977 |
Screw the green energy fad.
Stick with reliable traditional fuel. Trying to reinvent the wheel is REDICULOUS!
