Honda 450 Foreman quad question
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: Honda 450 Foreman quad question
    Posted: 07 Apr 2024 at 11:19am
Howdy,my new to me quad will leak gas out of the carburetor overflow tube when I park it for the day if I don't let it run out of gas after turning off the fuel shut off. Assume there is gunk in the float, carb repair is above my abilities. I'm running a heavy dose of Seafoam thru it.It starts and runs perfectly.There's not a line from the overflow tube to get the gas to the ground so if it does overflow it drips on the engine. I am going to put a line on it. My question is, the parts diagram shows a one way valve in line on the overflow tube. What does this valve do, keep water out if you are puddle jumping? Thanks for reading!
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2024 at 12:47pm
valve is not necessary.. but yes, it prevents water, bugs, dust from going UP into the carb.... You dont have it now, so adding a foot of drain hose does not change anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2024 at 12:48pm
Thank you Steve
Vaterlemon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaterlemon Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 51 minutes ago at 8:06am
Sounds like the float needle isn’t sealing. I’d pull the carb, clean the bowl, check the float height, and replace the needle and seat if they look worn or sticky.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 31 minutes ago at 10:26pm
repairing that carb is pretty easy  getting it in and out is the hardest  my one honda leaks once in awhile but i allways turn the gas off when i park for the day
This page was generated in 0.128 seconds.
