Honda 450 Foreman quad question
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: Honda 450 Foreman quad question
    Posted: 07 Apr 2024 at 11:19am
Howdy,my new to me quad will leak gas out of the carburetor overflow tube when I park it for the day if I don't let it run out of gas after turning off the fuel shut off. Assume there is gunk in the float, carb repair is above my abilities. I'm running a heavy dose of Seafoam thru it.It starts and runs perfectly.There's not a line from the overflow tube to get the gas to the ground so if it does overflow it drips on the engine. I am going to put a line on it. My question is, the parts diagram shows a one way valve in line on the overflow tube. What does this valve do, keep water out if you are puddle jumping? Thanks for reading!
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2024 at 12:47pm
valve is not necessary.. but yes, it prevents water, bugs, dust from going UP into the carb.... You dont have it now, so adding a foot of drain hose does not change anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2024 at 12:48pm
Thank you Steve
Vaterlemon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaterlemon Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 8:06am
Sounds like the float needle is sticking or the float height is off. I’ve had the same thing happen, and a simple carb clean plus a new float needle sorted it. I’ve also had good luck using genuine honda parts for little things like that, since the cheap needles didn’t seal right. Also worth checking that the petcock shuts off fully so the bowl isn’t being overfed while it sits.
Edited by Vaterlemon - 13 Feb 2026 at 2:57am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 10:26pm
repairing that carb is pretty easy  getting it in and out is the hardest  my one honda leaks once in awhile but i allways turn the gas off when i park for the day
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2026 at 6:10am
Its been several years now, but The carb failed on my Honda 300. The brand new oem replacement was available online and priced so to make more sense than repair at that time. We used ours everyday feeding cows.
That same 300 is giving me fits finding tires like the oem ones.
