Honda 215 blades
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Honda 215 blades
    Posted: 04 May 2019 at 6:16pm
I purchased a used Honda mower from a long-time client of mine last spring. I am used to Honda mowers as I previously ran a Harmony series( steel deck) that finally rusted out so am aware of the awesome engine performance. I finally turned the mower over this afternoon to take the "blade" off for a sharpening and to my surprise/dismay, it had 2 blades off-set by roughly 3/4 of an inch.
Am I to assume this is a mulching blade set-up? Can I just go to the local "box store" and grab a single 21" blade( mulching is not a priority) ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 6:44pm
Search agrisupply.com, they probably have the blade, and will ship it to ya...Wink
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:36pm
You will need shorter blade bolts if you only use 1 blade, it will contact the Blade clutch and mess things up
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:49pm
Unhappy Never gave that a thought until you mentioned it!! I have been searching online since my post and apparently that was the factory set-up (double blade)?? Thanks again!
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:56pm
Just bought a set for mine, Home Depot, in stock at local store.  Check their website.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 8:16pm
They were the first store/supplier to pop up on my google search LOL!! headed there in the morning. Thanks to all !! Have a safe mowing season Smile
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 11:43pm
whats wrong with getting them from your local mower shop the two blade setup does a nice job
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 6:34am
Nothing except by the time I got home from work and got the blades off, they were closed and I need to mow today (Sunday) Unhappy. I could possibly put the old ones back on, but just can't bring myself to do it seeing how bad of shape they are in-beyond touching up with a grinder also,looks like they've been "touched up" previously  by someone that shouldn't have access to a grinder LOL!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 5:24pm
OMG !! I can not believe the difference in performance with NEW OEM blades from a box store!! H/D had my style of blades in a HONDA sealed box that said MANUFACTURED IN USA!! I installed them this afternoon and couldn't believe the suction from under the deck! It was pulling leaves in from 15" away from the mower!!
