Hillside Plow |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: Hillside PlowPosted: 21 Jun 2010 at 9:10am |
I saw one of these advertised, but what is a Hillside plow?
Charlie
firebrick43
Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Posted: 21 Jun 2010 at 12:00pm |
My guess is its a two way plow. Ie it the plow either has two separate bottoms such as on a b/c or is a rollover like the later mounted allis plows. These plows were typically used in hills so you alway turned your furrow up hill.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34441 |
Posted: 21 Jun 2010 at 1:04pm |
As I understand it, a Hillside plow usually had an hydraulic adjustable bar that slide sideways to bring the plow closer or farther from furrow down on the 3pt hitch assembly.
cyclone
Posted: 21 Jun 2010 at 9:01pm |
hillside plow is a team draw plow you got to the end your roll you turned your team around .you lifted up on the handles kicked a catch and the mold board and point and turned over and the catch would catch.it had no land slide.
Brian G. NY
Posted: 22 Jun 2010 at 8:37am |
If this "paste" works, you will learn all you could ever need to about hill side plows.
cyclone
Posted: 22 Jun 2010 at 9:13am |
thanks brain for posting the pictures its been a long time since i saw a hillside plow.as a child in eastern Kentucky.we had one it was a vulcan. I had forgot all about it.thanks again for posting the pictures.
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 22 Jun 2010 at 11:02am |
My grandpa plowed with a Syracuse. We played with it as kids. It finally rusted away to nothing.
JC-WI
Posted: 22 Jun 2010 at 11:07am |
Thats an old tyme plow. What do the modern hillside plows look like?
ToddSin NY
Joined: 08 Nov 2009 Location: Newark,NY Points: 1034 |
Posted: 22 Jun 2010 at 11:13am |
We have a 5 bottom 3 point Oliver plow that we call a hillside plow. There is a cylinder on the front that moves the plow side ways about 12-18". This is so when you are plowing along a side hill and the plow is not up close enough to the last furrow plowed you can slide it up the hill to get the first furrow laid against the last furrow. This keeps you from having a gap in the furrows.
CTuckerNWIL
Posted: 22 Jun 2010 at 2:19pm |
I have a picture of an Oliver plow like that. It was in a park like area at a Mill and restaurant on the Blue Ridge Parkway.
ToddSin NY
Posted: 23 Jun 2010 at 3:31am |
CTucker I doubt you've seen them with automatic reset bottoms though! You fellows out there in no rock land don't have a use for them like we do here in rock country!! LOL!
