High wheel mower
welkerfarmsfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote welkerfarmsfan Quote  Post ReplyReply Direct Link To This Post Topic: High wheel mower
    Posted: 08 Oct 2020 at 10:47am
has any one ever seen a high wheel mower or have one because i have one and it is curently in peices as of now
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 9:24am
Kase, your going to have to put a lot more data into the post. What is the question ? What is the age of the unit ?  Are you trying to fix it ?  Basically a lawn mower motor with a belt driven blade ?
Is this what you have ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote welkerfarmsfan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 9:28am
no it is not but just look it up online and you will see it it has 2 little wheels in the front and two big wheels in the back and it is 21 inches but it is poapular in the south and not as populare in wisconsin
Post Options Post Options   Thanks (0) Thanks(0)   Quote welkerfarmsfan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 9:39am
its from 1978-1981
there are two types of cars fords and can't afords
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 10:07am
the one in steves picture is a Batchtold, I have one of them. the competetor to them and more popular was the Roof brand.
do you have any tags/numbers/etc. to work from???
Post Options Post Options   Thanks (0) Thanks(0)   Quote welkerfarmsfan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 10:08am
i will have to check at lunch time
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 11:08am
post a pic or two of what you have and it would give more of an idea. There were/are many mowers on the market fitting the description you gave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote welkerfarmsfan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 11:11am
ok but it is in peices right now so it wight be hard to tell what it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 4:05pm
so it is a 21 inch push mower with bigger rear wheels ?  Some have the rear wheels drive also ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2020 at 4:10pm
an older version... this would appear to have a SPINDLE on the deck, and the motor sets BEHIND the spindle and probably belt driven ?
Edited by steve(ill) - 09 Oct 2020 at 4:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2020 at 10:36am
Probably a Yazoo mower. HTH Tracy
This page was generated in 0.242 seconds.
