High Hour Allis Diesels |
Slim
Topic: High Hour Allis DieselsPosted: 07 Dec 2016 at 7:55pm |
So we've all heard the stories of high hour tractors of other colors. I'm just curious how many on the forum here could testify to how high Allis diesels can go without a rebuild. I'm interested as I haven't heard much at all on this and haven't lives long enough to see my own go high. Take it away...
-Slim |
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
Mike Kroupa
Joined: 02 Oct 2009 Location: pierce, ne Points: 338 |
Posted: 07 Dec 2016 at 9:04pm |
I have an early 80's 433I power unit on an irrigation pump that has right at 10k hours. Put new rod and main bearings @ 6400 hours back in 2002. Have rebuilt the water pump several times and replaced the turbo. Also have put on a used exhaust manifold, they like to crack. Also new nozzle tips. Other than that the clyn. packs are still original. It runs hard but the irr. pump only requires 65 HP. Uses maybe 1.5 gallons of oil every 200 hrs. I plan to keep it in service. Mike
HD6GTOM
Posted: 07 Dec 2016 at 9:50pm |
Have seen 7060 with 15000 hours on it using FS 15w40 oil. Motor never touched. Was traded for a 8070 and I lost track of it.
JPG AUSTRALIA
Posted: 07 Dec 2016 at 11:38pm |
Have a 7060 that was bought new in 76, has clocked over 11000 hours, no work on motor other than waterpump, injectors and new turbo.Transmission has never been touched or split. Oh and it uses no more oil than it ever did new.
Edited by JPG AUSTRALIA - 07 Dec 2016 at 11:39pm |
Gary(WI)
Posted: 08 Dec 2016 at 6:24am |
I have a customer that has an 8030 with 5 original hole in it Has about 11000 hours on it. Does not start good but still running.
He said it burnt a piston and they just replaced that hole probably 15 years ago
Same customer has 6080 with at 10000 that has never been touched
Edited by Gary(WI) - 08 Dec 2016 at 6:24am |
caledonian
Silver Level Access
Posted: 08 Dec 2016 at 6:53am |
Our 180 diesel bought new by my dad in 1970 has over 11000 hours on the original engine. Runs very good.
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 790 |
Posted: 08 Dec 2016 at 6:55am |
We have a 1960 D-17 diesel that before we rebuilt it the tech showed 9000 something hours but Dad can't remember when the tach stopped working. Been in our family since new and the only thing grandpa had to do to it was put a new head on in the early 80s when it cracked. Other than that it had never been overhauled. It was still running before we rebuilt it but was wore out by then. Who knows how many total hours were on it.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Peterson
Joined: 05 Mar 2011 Location: Westboro, Wi Points: 872 |
Posted: 08 Dec 2016 at 6:58am |
Buddy of mine has a 7060 that has over 17000 hours. Finally they rebuilt the engine last year. Sleeves still had the cross hatching visible in them. If you take care of the tractor, she will take care of you.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 08 Dec 2016 at 8:10am |
all depends on how they are taken care of. any brand will fail prematurely if it doesn't have good upkeep and regular service. I know, I've seen a lot more AC engines with longer time on them than other brands. just observing in our area thru the years, generally green tractor need their first overhauls about 5000 hours area, IH about 6000 hours area, and AC 7000-7500 hours area. I've also seen all brands have 10,000 + hours on them before first overhaul. I've also seen 50-70 year old tractors of all brands that have never had an overhaul (and no hour meters), might be safe to say they might have 20,000 + hours on them....but who knows?
cpg
Posted: 08 Dec 2016 at 8:12am |
I know its not a diesel but we have a WD in the family that my grandpa bought when it was just a few years old and it was his main tractor for many years plowing, running a roto-baler and all-crop because of its live power. He said it had the valves done once but estimates that since its last rebuild of the bottom end, just based on how many years ago it was and how much it was used each summer, it is probably at least 15,000 hours. Great old tractors. My dad still has it on the farm and I now have one of my own as my work tractor and wouldn't mind owning more if I find a good deal on another.
mintenfarmer
Joined: 22 May 2015 Location: Minnesota Points: 191 |
Posted: 08 Dec 2016 at 8:22am |
I have a Perkins in a 170 with 9650 hours with no known work, but my grandpa had a 185 with loader that was rebuilt at 2000 hours and the dealer said the oil rings were in upside down? and parked in a shed with a little over 2500 because reverse is the only gear that stayed in.
Edited by mintenfarmer - 08 Dec 2016 at 8:23am |
BigBadAllis
Posted: 08 Dec 2016 at 8:44am |
180, 185 and 200 all have more than 10,000 hours on them. Never been rebuilt or apart.
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 797 |
Posted: 08 Dec 2016 at 10:18am |
rebuilt a 200 with 27000 original hours, had a bad head on it from the factory Allis Chalmers replaced the head when it had 200 hrs on it, otherwise untouched, it had spun a bearing at this point. Same guy had a 210 with 17000 hrs had a new clutch, and a water pump.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Posted: 08 Dec 2016 at 10:48am |
6060 SERIAL #4945 WITH 10866 HOURS
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Unit3
Posted: 08 Dec 2016 at 11:21am |
1936 WC. Hours???
Jwmac7060
Posted: 08 Dec 2016 at 12:00pm |
We have a 7030 that has 13000 on it and it has never been touched..7060 has 22200 on it and it has been rebuilt once...have clutched them and torque limintered them both several times over the years....the 7030 has been set at 160 hp since the day it was new and the 7060 has been sitting around 220 its entire life
DougG
Posted: 08 Dec 2016 at 3:47pm |
I know of a few One Eightys that
have over 12000 hours on them , were in all farming details, 4 bottom plows , 12 ft discs during planting time , then the main hay tractor in the spring never missed a beat, a couple are still going strong
tornado8070
Posted: 08 Dec 2016 at 4:03pm |
My 8070 went 8000 hours untouched. had not been for dandeline fuzz it wouls still be going....
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
45 turboa-
Joined: 04 Feb 2012 Location: coral city wi Points: 441 |
Posted: 08 Dec 2016 at 5:09pm |
Our neighbor has a 200 witch we figure has approx.68000 hours it had run every day at least 3-4 hours every day since it was new. I did the last overhaul about ten years ago it was overhauled 3 times but the block was getting bad-leaking around the sleeves so we put a combine engine in it. In the summer most days all day long.But it will jump out of 3rd gear the trans has never been touched.The farmer that owned it pastaway 3 years ago cattle were sold so now the 200 just sits but its done its share of work.
turbocharged
Larry W.
Posted: 08 Dec 2016 at 8:09pm |
I have a customer that has a 6080 with over 9000 hrs on original motor. Even though it's not diesel, I have a 180 gas we've owned since nearly new, we are over 10,000 hrs on the motor, had a valve job once!
Slim
Posted: 08 Dec 2016 at 9:18pm |
Wow! I've heard of some pretty high hour engines, but some of these tractors you guys have mentioned are truly a stalwart testament to the Allis Chalmers engineering and design. They ran with the best of the other brands and are still going strong today. The legacy lives on. Goes to show as well that if you take care of your equipment, it will take care of you.
-Slim |
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1167 |
Posted: 08 Dec 2016 at 9:31pm |
Im amazed at some of these hours on tractors. Ive heard of a few with 13000 and not been. Most any Allis around has had the engine gone through by 5000 hours. Most are treated like crap. Most guys are proud of thier red and green stuff and if they have an Allis, its out back in the weeds or doing the dirty work with oil change intervals. Ill get called a liar, but I've heard my father say "you dont have to change it, just keep adding oil".
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Mike Plotner
Joined: 02 Apr 2014 Location: Central Ohio Points: 1577 |
Posted: 11 Dec 2016 at 12:19pm |
back in the late 60's grandpa toured a vegetable farm in Michigan as part of some dealer training and said they were getting extrodanairy hours out of tractors (like 10,000+) before overhaul because they always stayed warm. always plugged in when not running
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
