High engine oil temp
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: High engine oil temp
    Posted: 24 Jul 2022 at 12:52pm
1999 KW T800B, ISM, over 1 million on the odometer.
Coolant level good
Engine oil level good
Engine fan cycles normally, engine does not overheat.
Oil temp tops 230, and climbs driving at Hwy speeds, not a concern doing in town delivering.
Engine will shut down close to 240deg.
15w40
Question: is the oil pan temp sensor the only access for the ecm? Or, is there another sensor the ecm reads for engine oil temp?
TIA
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 6:45am
Thinking out loud here. Are you going only off the gauge reading or have you tried checking temp of oil pan with IR thermometer for comparison?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 6:53am
According to a friend of mine still in the commercial truck industry, the Oil Pressure and Temp sensor is a single unit, No Oil pan sensor.  If have a Gauge attached to a sensor in the pan it is on its own and not associated to the ECM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 6:56am
have no clue but...
is the oil PRESSURE good ?
?? if it was low, less oil flows, could heat up ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 7:01am
This engine definitely has an oil pan temp sensor, you see it standing on the ground, drivers side.
If too high of temp, idiot light and buzzer comes on, engine will shut down if temp hits 240 or so.
Do not have an IR gun, yet. But will be getting one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2022 at 7:08am
have no clue but...
About 35psi or so, at Hwy speeds. For a Cummins that’s not bad.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 9:25pm
That oil pressure is spot on for that ISM.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2022 at 9:35pm
There is a temp sensor in an oil gallery on the right side if I remember correctly. It will shut down if it's too hot. The gauge in dash is the sensor in the pan. Based on what you said put an oil thermostat in it. I'm pretty sure it has one but it's been a few years since I was that deep in an m
Edited by im4racin - 27 Jul 2022 at 9:36pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2022 at 12:25am
One thing that will cause the oil temperature to rise, is if the pump is ingesting air.  If there's a slight crack in the oil pump pickup, you'll get that ingested air on the upstream side of the pump, and a high pressure from the downstream side to the pump, where the much higher pressure compresses the (ambient temp) bubbles to a mush smaller volume.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2022 at 6:59pm
On a new truck that is true
Not on a 1999.  1999 would have the old style dash. And if the truck has the optional engine oil temp gauge then it will have a pan sensor
Should be the same sensor as the ones used in the rear axles, NOT the transmission. The one in the trans has a different temperature range. K379-12 is the old school pan sensor part number. You may try swapping it for a rear axle unit and see if that changes things.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2022 at 7:01pm
Unless it’s an aftermarket shutdown unit, which I have seen before, then that sensor is communicating with the ecm somehow. It’s the only way it can shut it down
1968 D15D,1962 D19D
