hi new here
rustler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustler Quote  Post ReplyReply Direct Link To This Post Topic: hi new here
    Posted: 12 Aug 2014 at 12:20am
Hi every one
I am looking for info on a l 112 loader for a b 112 the pump is leaking oil badly around the seal on the drive shaft on the pump can they be rebuilt
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 1:05am
If its got bolts, you can take most pumps apart... trick is to get them back together again ... LOL
 Take the end cap off and then get measurments or seal number and see a local dealer of seals...  Mic the bore and the shaft  and depth or thickness .  I usually order seals through the local oreily or carquest store... make sure you put the gears back in the way you take them out... they are "wear fitted".  LOL
