hi new here |
rustler
Topic: hi new herePosted: 12 Aug 2014 at 12:20am |
Hi every one
I am looking for info on a l 112 loader for a b 112 the pump is leaking oil badly around the seal on the drive shaft on the pump can they be rebuilt |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34616 |
Posted: 12 Aug 2014 at 1:05am |
If its got bolts, you can take most pumps apart... trick is to get them back together again ... LOL
Take the end cap off and then get measurments or seal number and see a local dealer of seals... Mic the bore and the shaft and depth or thickness . I usually order seals through the local oreily or carquest store... make sure you put the gears back in the way you take them out... they are "wear fitted". LOL
