Hey Coke HD5 question
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Hey Coke HD5 question
    Posted: 04 Dec 2009 at 2:11pm
How much counterweight should I have on a G? Probably cost me as much as the tractor did, if I can even find them, but I think it would save a lot of stress on the truck frames
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 3:36pm
OK, now I have two questions, son ran one of the tractors out of fuel. Will it self prime, or is there something i need to do?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 4:04pm
 I do't know how heavy is the HD5 counterweight but am still have one and
for the fuel he will prime him selve.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 12:05pm
My HD5G has 2 weights , which seems to balance well with full bucket. Without weights I have seen many machines with twisted truck frames from to much weight on front ideler, or bent axels in wheel.
 Only time i have a problem is backing up ramp with full bucket , machine wants to walk on track raising machine rear, instead of moving backwards
Have seen weights with the AC logo cast into them and also like mine just flat with a lift rod in csnter cast into weight.
 The 2-71 pump should prime the system but you could fill the filter cup with fuel. If you use the either sparingly to get it to run it will save on batteries. I use the 1/4" pipe plug hole in blower to add either.
Edited by Coke-in-MN - 05 Dec 2009 at 12:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 2:05pm
Yep, That's what happened to one of the two machines I have, the frame is (was, I fixed it) all twisted at the front idler, and I suspected thats what happened, someone did a lot of heavy lifting w/o counter weight. How heavy is a weight? I will probably build a frame work out of scrape and fill it with concrete, cheaper than buying real weights
Thanks for the help guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 3:17pm
Unsure what the weight is in lbs. as far as scrap value most counter weights were low grade and most scrap places do not want them.
 Friend junked several cranes and ended up paying a landfill to take the weights.
As someone has one , might be time for road trip .. LOL
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 8:04am
On my Hd 5 I weighed the counter weight one time, if I remember correctly, it was somewhere between 750 to 1000 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:44am
Thanks Wayne. I was guessing about 1000#'s would be about right
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 4:28pm
i'm trying to remember on my hg5, i think there was one weight above the drawbar on back, showed 1000# inscribed in the metal, it always seemed to stay level when the bucket was full of dirt. i don't have it anymore, otherwise i'd go look.
This page was generated in 0.227 seconds.
