Hex bushings or tubing source?
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Topic: Hex bushings or tubing source?
    Posted: 11 Mar 2010 at 1:20pm
Looking for some hex tubing or bushings to fit a 7/8" hex hub to a 11/16" hex shaft.  Does such a thing exist?  I'll only need about 6 or 7 pieces 2" long.
Maybe not in the right category, but I'll be using it on an Allis planter...
The innovators offer what others will imitate.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 1:41pm
Is that the size of the hex setup on the DA 385?   Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 1:44pm
Yes, the line shaft/drill shaft across the back is 11/16".  Any of the row-clutches I've found are made for 7/8" hex.  I could change out the shaft to 7/8, but then I also have to change bearing hangers and the main drive sprockets.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 2:11pm
This is where I go, if they don't have it, I go to my friend who is a machinist.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 2:34pm
Get a 6' length of 7/8 hex stock from Mcmaster Carr for $27 and have adapters made with internal keyways.  Cut the old shaft into segments and have the ends turned round with keyways.  Assemble the shaft in sections on the machine with setscrews holding it together.
Edited by Rawleigh - 11 Mar 2010 at 2:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 2:55pm
Is there any hex PTO telescoping drive shaft out there of the right dimensions?  I find plenty of splined couplings and adapters, but not much hex.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 3:20pm
I don't know how small a lot they will sell:
http://www.mstube.com/mech/index.html
