Here's my plan for wiring the CA |
J&J
Topic: Here's my plan for wiring the CAPosted: 14 Mar 2026 at 3:16pm |
Any thoughts or advice...
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 14 Mar 2026 at 4:58pm |
I would just get a wiring harness from "The Brillman Co." Www.brillman.com Just tell them when ordering what alternator you wish to use and it will be plug and play. There's no need to make it any more complex than it needs to be.
Joined: 11 Sep 2009 Location: illinois Points: 90645 |
Posted: 14 Mar 2026 at 7:23pm |
print looks good.. I think you got it....... I did the same thing 20 years ago... Made up 5 harnesses for "B" tractors...but i have toggle switch to turn ON.. then push button to START.... used them all..
Companies charge $160. just for the WIRES... then you need the switches and fuses if any. Cost is minimal if you got the understanding of electricity.. Edited by steve(ill) - 14 Mar 2026 at 7:27pm |
Les Kerf
Posted: 14 Mar 2026 at 8:25pm |
Anyone who will put that much effort into a schematic will have no problem building a first-class harness. ![]() I usually roll my own, but had Grandson do the wiring on the CA last year just for the education. Materials are getting quite spendy nowadays. |
Jgranat
Posted: 15 Mar 2026 at 6:27am |
I wire all my tractors similar to this, 5 ACs, 4 Fords, 2 Farmalls, no factory harnesses. Troubleshooting should be easy, if they ever fail me....every one is 12 volt negative ground.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25204 |
Posted: 15 Mar 2026 at 6:49am |
well, since you asked.... 1) remove one of the fusible links in the alt-bat feed 2) install a +-40 amp ammeter 3) replace 10SI with the smaller CS-130 series or a Denso unit 4) install a 4 place fuse block instead of the 'power ' fusible link 5) one color per function 6) crimp,solder, heat shrink all end connectors
Edited by jaybmiller - 15 Mar 2026 at 7:03am |
Les Kerf
Posted: 15 Mar 2026 at 8:17am |
Good points to consider. ![]() I much prefer a voltmeter rather than an ammeter, but I am too much of a cheapskate to remove a functional ammeter I am not a fan of fusible links. The 10SI alternator is indeed a tight fit on a Model CA as there is not much room for adjustment next to the steering arm, but it can be made to work so long as the adjustable pulley on the water pump isn't rusted tight.
jaybmiller
Posted: 15 Mar 2026 at 8:45am |
voltmeter can lie, only shows the potential or possible energy whereas an ammeter ACTUALLY shows electrons moving in and out of the battery. 'they' went from ammeters to voltmeters as a cheap cheat.. as they're easier to intall( cheap and universal).
J&J
Posted: 16 Mar 2026 at 6:44am |
The Brillman wiring harnesses are nice but do not offer the options that I want, plus I like to upgrade the wire sizes. I do like their Cotton braided spooled wire options.
I Probably will go with fuses rather than links, I like the "sealed" blade style fuses. I prefer a voltmeter over an ammeter for safety, ease of wiring, more compatible with an alternator. I just want to know if the battery is charged/charging. I already have a 10 SI that barely clears, when I need a new one I'll probably go with a CS – 121 it's even smaller than the 130. Do you all usually run 2AWG battery cables as an upgrade for 12 V?
PaulB
Posted: 16 Mar 2026 at 7:20am |
If you were to call John and discuss you desires, he nearly makes all of his wiring harness to order and as I said to begin with he can customize a harness to your needs.
i-888-274-5562
Jim.ME
Posted: 16 Mar 2026 at 7:34am |
It might be worth checking with Steve at B and B Custom Circuits for a harness.
Jgranat
Posted: 16 Mar 2026 at 11:28am |
Bigfoot and a lying volt meter are two things I have never seen in my life. In nearly 57 years on the planet I've never experienced either one.
Les Kerf
Posted: 16 Mar 2026 at 12:11pm |
![]() Yup. A voltmeter tells me more than does an ammeter, but I grew up driving VW's that only had an idiot light, so an ammeter seemed like an improvement .All three together (Volts, Amps, and warning light) would be the best system. And yet, somehow, life goes on!
Les Kerf
Posted: 16 Mar 2026 at 12:18pm |
Only if I already owned them, my Model C has puny 6 gauge cables on 12 Volts and it just SLAMS that starter in.
Posted: 16 Mar 2026 at 1:30pm |
if your upgrading to 12v, the #4 or #6 battery cables from NAPA or Auto Zone are plenty big for a 100- 200 cubic inch low compression engine..
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8658 |
Posted: 19 Mar 2026 at 1:23am |
J&J
You are doing fine and have forgot more about this than I have known. Looks like you'r on your way. What ever you do you will end up with a non stock wiring system. But it will be a fresh improved system! The Denso alternator worked good on our CA. Regards, Chris and Cheryl
J&J
Posted: 19 Mar 2026 at 10:02am |
I've learned a lot with this wiring project. We're going through the starter now, new brushes, bushings, springs, wiring, and 12V field coils.
The head, block, and crank came back from the machine shop, so getting ready to build the engine. I need to go through the hand clutch, gonna need some help with that, I've never worked on one of those!
Posted: 19 Mar 2026 at 9:16pm |
this may give you some ideas on the clutch......
Thanks(1)
Posted: 19 Mar 2026 at 9:19pm |
and from our Local Experts...
CA13414
Posted: 22 Mar 2026 at 8:43pm |
Awesome job on the design.
I did the same when we wired our CA. Was easy to layout the individual wires as drawn. Agree with soldering ends to crimped connectors when possible and heat shrink the ends. I found heat resistant braided cable sleeves and ran all the wires through the sleeves. Used heat shrink at the ends of the sleeves as they each jointed the next. Thus, was able to insert that into the next sleeve and secure with a larger heat shrink. Did this for each as they came together and as I progressed towards the control box. Then attached everything to the frame with stainless steel rubber cushioned cable clamps. Looked great when it was done. Dan Edited by CA13414 - 22 Mar 2026 at 8:46pm |
CA13414
Posted: 22 Mar 2026 at 8:52pm |
At some point, I like the idea of adding a solenoid and push button vs. the starter pull.
J&J
Posted: Yesterday at 6:41pm |
Nice work on your 1953 CA!
CA13414
Posted: 12 hours 57 minutes ago at 6:15am |
Thank you, had fun doing the rebuild and has been a great little tractor.
In addition to the above links, here is the page were we detailed repair of our hand clutch. It was slipping when pulling a load. In retrospect, I think it was was easier to repair the hand clutch vs. what it would have taken to repair the engine clutch...... the alternative slipping clutch with a load. Dan Edited by CA13414 - 12 hours 55 minutes ago at 6:17am |
