Henry Backhoe Spool Valve Issue PLEASE HELP
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Henry Backhoe Spool Valve Issue PLEASE HELP
    Posted: 09 Sep 2013 at 6:58pm
Looking for information on how to remove a Lift Check valve from a spool valve on a 1963 Henry Backhoe ????
The IPC showes one Lift Check valve on each of the 4 spool valves of the 4 leaver hydralic package.  The Lift Check is an internal component of the spool valve and is located between the hose conections on the valve body.
It looks much like a freeze plug with a ring around it, however it has no exernal retainer or visible retaining fastener.
My Question is:  How do you remove the Lift Check valve.
Thanks in advance
Edited by Macon Rounds - 09 Sep 2013 at 7:02pm
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 7:06pm
Macon Rounds:  Is there a snap ring holding it in place?  If so am wondering if the snap ring has holes in the end so snap ring pliers could be applied to remove?
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 7:27pm
I have a valve set up from d17 industrial for sale, believe it had a henry valve
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2013 at 7:42pm
No visible retaining ring.  Snap ring ETC...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 4:26pm
Still looking for the magic trick to remove the lift check valve.  Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 5:05pm
Who is the manufacturer of the valve?  Gresen, Hydreco, Prince, Bee-Gee. See if you can get any info off the valve bank
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 6:19pm
Ben, post a picture on here, maybe someone can recognize it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2013 at 6:35pm
Backhoe is in Pa.  I am currently in Ga.  will be up there next week to repair it or ......  To take photos as you recomended...  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2013 at 7:09pm
D17 Brown
Sent you a PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2013 at 7:35pm
Anyone have a spool valve off a 1963 vintage henry Backhoe ?  It may just to  replace it.
