Henderson Bucket |
CAPTMARCO ![]() Bronze Level ![]() ![]() Joined: 15 Oct 2019 Location: Kewaunee, WI Points: 63 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Sep 2020 at 9:54am |
Gentlemen,
I saw a guy selling a henderson bucket setup that he had on his B, curious if I can use that same unit on my CA? Anyone know anything about this type system or if it's worth it on a narrow front? I know the pump goes on the PTO and it's relatively self contained but I know nothing else about that system. Thanks!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5156 |
The framework is most likely a little different for mounting on a B than what it would need for a CA, however it probably could be modified to fit. A loader is the one thing I would never again have on a tricycle tractor. A tricycle will push around too much in the mud compared to a wide front. The CAs hydraulics would be more than adequate for the loader if the cylinders are made for the higher pressure.
Ricky D ![]() Bronze Level ![]() ![]() Joined: 13 Sep 2009 Location: Waterloo ON Can Points: 57 |
Henderson cylinders take CA hydraulics, I blew the end out of one on a friend tractor when I was a teenager. After he warned me not to go to the top. That was a loader he took off his B w/charlyn pump, & put on the CA
