help |
LionelinKY ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Radcliff,KY Points: 695 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Nov 2010 at 8:09pm |
Well, I got a picture up there but it doesn't leave me any room for text or anything else. I was hoping to type some text and insert a few images for all to see. What am I doing wrong? How do I resize pic to post smaller? Thanks-Lionel
roughstock ![]() Orange Level ![]() Joined: 16 Jan 2010 Location: Michigan Points: 690 |
What I do, is after uploading an image, I change the height and width to 33% of the default size. Also type your message first and then insert image. I hope this is the help you're looking for.
Brian |
Jeff(WD45-SATX-TN) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Lionel,
Before I insert a picture I hit the retun key a few times. Or, type your text first then hit the return key to give some space between your text. If you type after a picture, once it is in the field hit return key and type away.
Thats how I do it. Hope that helps.
Jeff
1954 WD45 NF "Iron Tater"
