HELP!!!!
kenm1975 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenm1975 Quote  Post ReplyReply Direct Link To This Post Topic: HELP!!!!
    Posted: 29 Aug 2015 at 1:44am
I have a A/C 620 need pics of wiring from engine to tractor and battery to starter. Someone did an extreme hack job on the wiring when the previous owner had it. I'm trying to make it run again. Also need the shroud that the cooler mounts to on the left side and the rubber washers for bother sides.
Thank you for looking Ken
Edited by kenm1975 - 29 Aug 2015 at 1:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2015 at 7:38am
We offer different repair sections for 620/720 Tractors if you need to repair a certain section. We also offer a complete wiring system for the Tractor also. Visit our website to see the different sections that we offer for repairing the OEM system if interested.
Steve@B&B
bb-customcircuits.com
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 10:57pm
you will be time and money ahead getting a harness from steve than trying to save someones mess the original harness and switches are  old and unreliable any way
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenm1975 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 9:43pm
I am putting another onan cckb in the tractor. It has four wires coming off the stator. It uses a rectifier and separate regulator. The regulator is missing one most wires were cut when replacement engine was removed. I am working with wire diagrams and would like some pics to make sure I'm wiring it correctly.
This page was generated in 0.112 seconds.
