help with priming a 45 diesel |
diesel dave ![]() Bronze Level ![]() ![]() Joined: 01 Oct 2010 Location: cincinnati Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Oct 2010 at 4:03pm |
how do i go about priming a 45 diesel
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
THE WAY I DO IT IS TO START AT THE TANK FILTER.DRAIN TILL NO AIR.NEXT REMOVE THE 2 PLUGS ON THE ENGINE FILTERS.USE A SQUIRT OIL CAN OF DIESEL.FILL TO THE TOP.GO AND HAVE A BEER,TO LET ALL THE AIR ESCAPE IN THE FILTERS REFILL WITH FUEL,REPLACE PLUGS AND THE ENGINE SHOULD CRANK NORMALLY..WORKS FOR ME EVERY TIME...
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
An unorthodox way of doing it is to either crack the bleeder screw on the top of the second filter, or crack the line at the top of the third housing that comes from the second filter. I then pressurize the tank lightly with the air hose and an air nozzle and a rag around the fill hole. I guess you could do it on the return line connection fitting and leave the gas cap on, but I did it in the fill hole as I didn't want to blow the tank up. I then watched and just gave it small shots of air until it started coming out the first bleeder screw and then after I tightened that up and loosened the line between the second and third filter, when it started coming out of there. I then cracked the pressure line on each injector and cranked until I had fuel coming out of each one, and then I tightened each one and cranked again. I remember cranking forever to get it to fire up the first time after the engine was rebuilt. Make sure your linkages are correct on the pump, and that the throttle lever is moved to half throttle so that the pump isn't shut off. When I did mine, it took me awhile to figure that out, as I was missing some linkage there and ended up making my own, to get the pump to open up and shut down properly. Good luck.
Rawleigh ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
As a variation on that approach, a cut piece of innertube with the fill valve on it hose clamped over the fill tube will allow you to go forward and operate the bleeder screw without the chance of air getting back into the system after you stop blowing air in the tank.
I primed my D17D using a shop vac. Just put the hose on the outlet side of the vac and put it over the fuel filler. Loosen the supply line at the pump and use the shop vac to pressurize the tank. Once fuel comes out steady, tighten the line and it should start fairly easy.
