Help with plow ID
Kevingweq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevingweq Quote  Post ReplyReply Direct Link To This Post Topic: Help with plow ID
    Posted: 19 Sep 2020 at 9:39am
Saved this plow , An athens disc , and a Woods Brushbull mower from the scrappers
Literally rescued them from a dumpster !!!!!
Any help on identifying the plow would be much appreciated ,along with any thoughts on how old or model .  Pretty sure it's a Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 12:38pm
Look for casting numbers on hubs and many other places for clues.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 3:04pm
Don't know the model but is a JD, plowed a lot of acres with one like that behind a WC or WD.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 6:57pm
Need the casting number on top of the beam. It's a JD, but what model it is can be identified by this number and cross referencing.
Edited by steelwheelAcjim - 19 Sep 2020 at 7:00pm
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
allisbred View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 5:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevingweq Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 9:42am
Thanks for all the help , Much appreciated !
"allis bred" Your link would not work for me . But thank you
Edited by Kevingweq - 20 Sep 2020 at 9:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevingweq Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 10:25am
According to the beam numbers (612 and 613) It is a #52 , 2 bottom tractor plow
Again thanks for help
  • 612 No. 52 tractor plow SB 1935-newer
  • 613 No. 52 tractor plow SB 1935-newer
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 12:52pm
I noticed it has the clevis.  If I remember correctly, they can be rare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 5:48pm
Not sure how that link did that from my phone, takes you to same place though. looks like you’re on track! Kevin
Edited by allisbred - 21 Sep 2020 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevingweq Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 8:09am
John,  Is the clevis you refer to the "teardrop" shaped one near the front of plow ?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 9:03am
I believe that hitch was only used by J.D.
Dusty
This page was generated in 0.305 seconds.
