Help with My WD
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: Help with My WD
    Posted: 08 Nov 2010 at 9:23pm
My WD has been sitting awhile, it needs to be re-wired. I finally got it in the shop and started servicing it out. I pulled the drain plug and the oil was a gray color. I assume this is from condensation. So I drained the oil and now want to flush the motor out. 1- do I put oil in and run it and then drain the oil and put more fresh oil in. That is the idea I had. 2- would you put a new filter on with the first oil change and then another new one after you flush it out, or would you use the old one until you were ready for the second oil change?
I am going to flush the rear end and hydraulic system out with diesel.
My next question is I need to know where to obtain the best wiring harness for my WD WITH INSTRUCTIONS FOR DUMMIES! RIght now it is run off a 12V generator and I what to switch it to a 12V alternator. I dont know who wired it up last time but the voltage regulator is underneath the hood, not mounted on the generator like it should. Anyway any help would be great. Thanks  Anthony
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 5:21am
I got my WD harness from Steve on here..installed easily and looks very professional.
Life is short...Make haste to be kind
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 6:25am
You can try OK tractor in Mounds, OK. They post on here and have a wesite also.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 6:39am
Steve from B&B provides wiring packages and excellent support.  He is on the forum under "Steve in NJ"
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 9:13am
THanks guys
