help with engine idle surging,,,,,, |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: help with engine idle surging,,,,,,Posted: 06 Mar 2020 at 9:57pm |
Our oldest Son has a 2000 Hyundai Elantra with the 4 cylinder engine and has got me buffaloed,,,, The car started getting a very high idle ,,,so I had him pull the throttle body as it had never been off and figured it was gummed up. After he got it off it was really junked up so,,,two cans of carb cleaner later,,it was finally good as new. He reinstalled it and now the engine just surges all the time. We did not bother any other part of the intake manifold neither can we hear a vacuum leak,,,,?? It just surges from idle to bout 2500 RPM,,,, Any ideas ,,,anybody ???
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 06 Mar 2020 at 10:06pm |
Check with a vacuum gauge. A lot of times you can't hear it anyway. Even with GOOD hearing, which I don't have anymore.
I'd guess then that it could be a little slug of something in it, or the MAF sensor or the throttle position sensor. Damn electronic crap.... Good luck Buddy. Did you do the suggested steps?? Take out screw A,,,,,,,have a BL. Take out screw B,,,,,,have a BL. etc. |
fixer1958
Posted: 07 Mar 2020 at 6:42am |
Spray around the intake gasket with carb cleaner or propane. Torn or cracked snorkel tube to the throttle body. Binding throttle cables can hold it open just enough to confuse the chit out of the PCM. Check the egr for vacuum leaks if it has one.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 07 Mar 2020 at 9:18am |
Most vacuum leaks are too small to hear but big enough to confuse sensors. re-trace your steps of what you touched during removal and re-install. It sounds like some of the crud got washed into a small hole or jet during cleaning.--- another thing on these electronic control cars is that once something is touched, usually takes 200 miles of driving for them to reset themselves, so try that next. TPS are picky too and it may be sticking.----could have been about ready to go south on you. There is a way to test them, but I dont know the procedure on your car. You can look it up in the tester manual.
desertjoe
Posted: 07 Mar 2020 at 9:49am |
OK,,well my Son says HE can hear a vacuum leak,,but I cannot,,,
,, so gonna try the sprayin around the intake manifold as I don't see any bad vacuum hoses,,,another thing he said was that when this started,,the engine would always like backfire out the intake BEFORE it would start then stumble for a few seconds before it would start running,,,,,? |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 07 Mar 2020 at 9:55am |
Ok, look at it this way... TWENTY year old import... probably designed for 5-7 years, like the 'Big3', so ALL the 'rubber' vacuum hoses should be replaced. In moving #3 hose, it opens crack in #2 ,after you've replaced hose #1. Dang, ANOTHER leak....Don't bother wasting time, replace them all.
shameless dude
Posted: 07 Mar 2020 at 8:53pm |
yep
Dnoym N. S. Can.
Posted: 07 Mar 2020 at 9:09pm |
9 out of ten time it`s a vacuum leak around the intake manifold at the head will make them idle hight B:-) Dnoym |
desertjoe
Posted: 08 Mar 2020 at 12:14am |
Well,,,Now I know why them oriental people gots little bitty hands,,,,,Dang but they used pretty much all the real estate under the hood of this mofo,,,,,!!!! WHY,,didn't the friggin engineers just rotate the engines and make the intake manifold be in front of the engine instead of at the rear where there ain't no room,,,!!! My hands is gonna not like me tonight as I really struggled on gettin to the 4 bolts on the backside of the intake manifold,,,,whoooeeeee,,,but I finally got it off...!!! The intake gasket tells the story,,,at one place the gasket is broke between two cylinders and at another it was leakin to the outside or rather to the inside. A lot of his problems were the injectors. 3 of the 4 must of been shooting straight gasoline as the intake ports are gummed up BIG time. Only one even looks close to have been spraying clean,,!! Here's something to think about,,,, I called Oreillys and Autozone for the replacement injectors and like to fall over,,,,$117 EACH,,,yep, $117 EACH,!! So, for the heck of it I check out Ebay and there are several sellers the list a set of 4 for ,,,,,$40 yes,,,$40 for a set of 4 reman injectors. So, I go back to Oreillys and the ones they sell are remans also for $117 EACH or $468 for 4. Amazon has the same injector set of 4 for $48. Something ain't right and somebody is makin a killing selling theirs for $117 each. That ain't captalism,,thats plain gouging the consumer. I can wait for 3-4 days and save $428 bucks,,,,,
jaybmiller
Posted: 08 Mar 2020 at 5:34am |
'engineers' NEVER,EVER work on the stuff they design, NEVER. Slappin an iron ring on don't mean you KNOW squat ! My American would never hire any of them. NAPA, closest auto store to me has OBSCENE prices. I can literally drive past them 10 minutes and save 25-75% on everything.... oh yeah clocks need to Spring Ahead.....
Dnoym N. S. Can.
Posted: 08 Mar 2020 at 6:16am |
[QUOTE=desertjoe]A lot of his problems were the injectors. 3 of the 4 must of been shooting straight gasoline as the intake ports are gummed up BIG time. Only one even looks close to have been spraying clean,,!!
you may not need injectors because with an intake leek the o2 sensor show an lean reading so the computer add more gas to make up for the lean reading to keep the 02 sensor happy because of the intake leek it dosn`t suck the gas in as well so add more gas so there lots of gas in the intake HTH B:-) Dnoym |
desertjoe
Posted: 08 Mar 2020 at 7:45am |
Well,Dnoym,,all the excess gasoline in the 3 chambers would explain why the car would backfire when trying to start engine,,,Those 3 combustion chambers are really gummed up big time is why I thought the injectors had issues with not atomizing the fuel and gumming up the chambers,,,??
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 08 Mar 2020 at 8:47am |
They might clean up they might not, but for $48 I'd get the new ones especially if ya don't have to send the old ones back for core charge refund. Then if they do clean up you can save em or resell em.
desertjoe
Posted: 08 Mar 2020 at 10:44am |
Yeah,,Chask,,I'm fiddin to order those on Ebay. I'm just so danged flabbergasted at the obnoxious difference in the prices,,!!I'm tempted in pullin a Shameless,,,and go to Oreliiys and show em what I'm buying,,,,Jimminie St OPatricks,,,,!!!!
chaskaduo
Posted: 08 Mar 2020 at 11:48am |
Yeah they advertise here they will beat any bonified brick and mortar store advertised price by 5% or $5. They'll scream it's Ebay, but they might give you 5% to still make the killing. $117 - $5.85 (5%) = $111.15 before tax, so you could buy 2 sets and pay the tax for the price of only 1 at discounted price.
The $48 Amazon ones might have the free shipping going for them. Edited by chaskaduo - 08 Mar 2020 at 11:51am |
chaskaduo
Posted: 08 Mar 2020 at 12:07pm |
Rock Auto has new injectors for $26.79 each in case you have to look elsewhere.
https://www.rockauto.com/en/moreinfo.php?pk=3070200&cc=1363126 About the injector
desertjoe
Posted: 11 Mar 2020 at 3:36am |
Well,,I had to order the intake manifold gasket, and it finally came in yesterday. Got everything cleaned up and manifold installed,,them 4 bolts on the back wasn't so friggin bad goin back in. Got everything lashed up and waitin on the new injectors susspossed to be here tamarrow. I'll bet thet little ole engine is gonna purr like kitten,,,, ![]() MANY THANKS for all the kind words and ,,,Help,,!!
Edited by desertjoe - 11 Mar 2020 at 3:37am |
chaskaduo
Posted: 11 Mar 2020 at 2:52pm |
That kid has got to love you. We already know how you feel.
