Help With Allis Chalmers EB
Valiant Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Help With Allis Chalmers EB
    Posted: 30 Nov 2019 at 2:14am
Hi all,
Today I picked up a Allis Chalmers EB
I don't really know much about Allis Chalmers tractors, so I will need some advice.
Where do I find the serial number?
This tractor has no brakes, there is only one brake band.
I would eventually like to restore this tractor, This is an ex boat tractor hence all the rust
What do you recommend for removal of the rust? I don't have a sand blaster.
I'm sure that the pictures will give you more of an idea!
Thanks for your time!
Samuel.
https://postimg.cc/gallery/2bce9rf16/83fb05e1/
Let me know if the link doesn't work.
Edited by Valiant Farmer - 30 Nov 2019 at 2:17am
JC-WI View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 2:27am
Making your link a hot link...  EB, that is an interesting tractor... like a cross between a B and a C model Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 2:53am
Thank you for that! I'm Quite thrilled about finding her!
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 4:51am
Hi                  here a little info for you
After the second world war Allis Chalmers operated factories in the United Kingdom at Totton (to 1949) in Totton Hampshire and Essendine in Rutland. Formerly the Minneapolis-Moline factory.
Model EB (1950-1955) British built model B with a straight front axle. EB serial numbers from Essendine works began at EB-4001. Some 2000 were assembled at the Totton, Southampton facility between 1947/9 from imported CKD kits but using US serial numbers locally stamped with an additional E prefix. Theoretically there may be duplication of serial numbers with later English production tractors.
. English-built models have an 'EB' serial number.
B Serial Numbers:
Location:On top of transmission case, by shift lever. English-built models have an 'EB' serial number.
photo of B serial number
        HTH
            B:-)                Dnoym
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 6:33am
Sam, your Tractor # is there in your photo album. You've got yourself quite the rust removal job ahead, many ways of removing rust, each with its pros and cons of time, effort, quality, and cost. Electrolysis, abrasion, and chemical, OR nothing at all. Welcome to the forum and enjoy your Allis and new found friends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 7:53am
A decent fab shop can make the new front axle assy. channel. May be far cheaper than sourcing a newto you replacement as I had done on a D12. That way you can cut around the good parts like spindles vs. forcing them apart, clean em' up and hopefully re-use them as that axle assy. is toast.
Kiwi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 6:43pm
Welcome to the forum I have messaged you and left me phone number if you need any help please call I am in New Zealand South Island so can help with some parts if needed
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 8:07am
Sam,
Welcome to the forum! Awesome looking EB. Guess I learned something new today.
Rear tires look almost new. Unique tread design!
Good pictures in your Album.
I use several rust removal process as mentioned. But I use electrolysis on a lot of things.
Of course sanding grinding wire brushing, and sandblasting all have a place too!
Good luck with your restoration!
Edited by Sugarmaker - 01 Dec 2019 at 8:09am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 8:23am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 8:29am
many of the Bs had rear hubs that mounted on the shaft spline. Yours actually is the optional 5 bolt flange mount... and your "HUBS" are mounted backward and the tires are mounted outboard as far as possible to make the tractor extra wide... You can make much narrower if you want , or any width in between.
Edited by steve(ill) - 01 Dec 2019 at 8:30am
Unit3 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 12:03pm
I never knew there was an EB until now. Thank you and a nice little history find.
  Now go check out the B's on Tractor House. Is that one with rear steel wheels? And if you want to buy me the one in Pennsylvania for my Christmas present, that will be fine.
Edited by Unit3 - 01 Dec 2019 at 12:04pm
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 12:29pm
That’s a very cool AC!!! Love the license plate and is the battery box set in backwards from our US counterparts or is that my eyes tricking me?And it looks to be dual fuel I assume at one point with the aux tank cutout in the hood.Very cool indeed and welcome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:44pm
Sam,
If you hang with MD he will talk you into flipping the finals and making it into a low rider!:) Which would be a pretty cool ride and probably not many like that in your area!
Post Options Post Options   Thanks (1) Thanks(1)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:51pm
Sam,
😂😂😂...well maybe not this one.
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 9:57pm
Sam- Congratulations on finding a great little tractor!  I have a '38 hand-start B, and a '48 B that is amazingly simillar to yours, except it has a non-adjustable curved front axle.
Just so you know, rust was a standard feature on all antique tractors... but beware- if you remove it, you'll void the factory warranty...   Wink
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 11:12pm
Welcome aboard. I dont remember ever seeing one. Thank you for the post. Good luck with your project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Valiant Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 2:51am
Hi all!
Thanks for all the help and info!
We have started pulling it apart - pulled the distributor cap off the magneto, and found that the rotor was extremely rusty on the conductive end, so  cleaned the rust off with some 600 sandpaper, and it ran beautifully!
Before it barely was running on 2 cylinders, and you could hardly start off in 1st! Now I can start off in 3rd!
I have cleaned up the front axle a bit to see how it was, not much holding it together!
The only thing holding me up now is the fuel tank fell off Allis when I was driving and snapped the pipe going to the fuel bowl.
I have attached some more pictures.
https://postimg.cc/gallery/2ns2vurfe/fd44d11d/
Thanks
Edited by Valiant Farmer - 04 Apr 2022 at 4:54pm
PSALM 119:105 : Thy word is a lamp unto my feet, and a light unto my path.
JeffC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2022 at 11:57pm
Hi Team,
just got a hold of my Allis Chalmers B model and it has a serial number of EB6027, so according to the knowledge here it would be an English Variant made in 1951.
Now to figure out what the engine serial number means, it says 715130!
I am in Ball Bay, Qld
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 12:29am
Hi jeffc has it got a pan seat  by the serial number it's a uk made not a uk assembled
Tractors Allis EB,two C,diesel G
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 3:33am
Sorry, What is a pan seat?
If you are talking about the seat where you sit, it has a normal single seat mounted on a U shaped piece of spring steel and a short shock absorber under it. It is not a timber bench seat
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 3:50pm
Hi yes it sounds like you have the pan seat the number 715130 is the casting number the engine serial number is on the engine just below the fule tap where the engine bolts up to the bell houseing it will start with CE or BC but should be CE  unless it is fitted with a P3 perkins diesel which some of the English variant are .
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 4:53pm
hi Kiwi, mine is a petrol number. I looked on the left hand side (from the front) and couldn’t find any numbers where you described
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 5:56pm
Just a photo on where to look. taken on my EB 1950
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 10:41pm
ok, fund the engine number with a bit of degreasing. It is not on the flat part of the engine block, but on the 1” wide ridge that bolts to the gearbox.
Anyway, my numbers are CE 3461 K.
Googling furiously to see what this means
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2022 at 10:54pm
This page was generated in 0.088 seconds.
