Help with 55 B cultivator/lift!
PulliamSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PulliamSB Quote  Post ReplyReply Direct Link To This Post Topic: Help with 55 B cultivator/lift!
    Posted: 26 Aug 2016 at 5:54am
Hello all! I'm brand spanking new to this page, forum AND Allis Chalmers. I picked up a 55 B with a double bottom plow, scape blade and side/read cultivators last week for a deal and need help figuring out the cultivator hookups. Now, I know there are a plethora of images available in Google and other threads.. But I haven't found anything similar to my tractor. There is a second cylinder from the lift pump that sits under my left foot on the tractor. It goes to the center bar in which the cultivators hook too.. But I'm not sure how to use or install them properly. I guess for starters, what's this secondary cultivator lift called? And I'm assuming the two way lift lever I have controls it as well. Also, any suggestions on hooking the cultivators up to it? Each side has two cultivators to install (not including the additional rear cultivator bar) Any help and reference to this tractor would be much appreciated. I'm a meant to the Allis world. Thanks guy!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 6:30am
First off, welcome to the forum. You might get better response posting this in the farm equipment section. Lots of knowledge here on the forum. Someone should be able to help you.
This page was generated in 0.289 seconds.
