help WD snap coupler lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: help WD snap coupler lever
    Posted: 06 May 2011 at 10:49pm
Hi all,
My 1950 WD came with no snap coupler attachment. I bought one and am trying to get it put on. I have the bottom snap coupler yoke installed, and I need to know where the lever (you use your foot on it to open the snap coupler I think) that has the chain attached to it is positioned? Can any one put up some photos to help?
Thanks
Pastor Mike in Iowa
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 6:20am
It goes under one of the bolts on the left side of the transmission.  I can't remember exactly which one at the moment.  You wouldn't need a good 2-14 snap coupler plow to test that hitch, would you?
AaronSEIA
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:01am
Aaron is right, but there are about three different bracket that are used and they attach differently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:50pm
Ok guys...my lever is a rod that is bent and it has a bracket that has one bolt hole in it...
Aaron,
How good of shape is the plow in? I have a 3 bottom snap coupler plow, I might trade even up if you are interested. I want one that is not worn out and one that is scoured good already...In using the three bottome I would need to get weights for the wheels, as I do a lot of spinning...The three I have has decent moldboards etc...but it needs to be pulled in a little sand to scour them up good,,, I don't have any sand here.
This page was generated in 0.112 seconds.
