Help!! Something happened to my WD
Phil (WY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Topic: Help!! Something happened to my WD
    Posted: 17 Jun 2010 at 10:13pm
I was driving over to pick up my newest buy, a SC carryall, with my WD and all of a sudden it made a couple of loud knocks and died.  I tried to turn it over with the crank, because the starter wouldn't, and it wouldn't budge.  So I pushed it off the road down a bank and as I did I had it in reverse and let the clutch out.  When it turned over a little, backwards, I put it in 4th and let out the clutch and it started.  It ran rough for about a minute or two then died with the same noise again.  Do you think it is the starter or possibly the hydraulic pump?  Thanks for your help!!  Phil
Kev Card View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev Card Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 11:07pm
Phil will it run with the engine clutch disengaged Kev
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:27am
Sounds like a broken connecting rod to me.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:07am
Sounds like some serious engine trouble. I wouldn't try running it again until you get it home and check it out. Trying to run it with broken internal engine parts would cause a major disaster. Did you check the oil condition and level? Sounds like the engine seized up. The engine will break loose temporarily, but trying to run it again will make it worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:10am
happened while runnings, so i would guess NOT the starter or hydraulics. I also think loose connecting rod.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:14am
I would pull the starter just to be 100 percent positive that its not the starter nose cone . I had one that must have not broken completely into when the engine cranked but it did shortly there after.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:45am
Phil,  It sounds serious.  All I can do is wish you the very best of luck.
Let us know how it turned out.
Good Luck!
Bill Long
