Help! Opinions!! Clutch Slipping on WD45
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Topic: Help! Opinions!! Clutch Slipping on WD45
    Posted: 01 Jun 2011 at 6:52am
Have wd45 that will not pull, no smoke and shifts fine. Which clutch is slipping? Engine or Transmission.  Thanks !!! Teddy
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:17am
I believe if you engage the PTO and let out the foot clutch and the PTO spins then the foot clutch is good and it's the hand clutch that's bad.  If The PTO won't spin then it's the foot clutch.  I think, it's been a few years since I was on a WD45.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:38am
I believe for Stans plan to work you would need a load on the PTO, there could be sufficient drag on a slipping clutch to turn the shaft w/o load.
If there is no smell or smoke my money is on the hand clutch. Both clutches are adjustable....if you have any left
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:45am
Lou is correct, to be sure it would need a load on the PTO which may be a problem if it's not already hooked up to a mower or some other PTO driven tool.
1968 one-seventy
1956 F40 Ferguson
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:47am
Call me and I will tell you which clutch, and how to test it. 205-242-7707. Wood.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 8:12am
You don't need a load on the pto, it is gear driver and when the ground wheels stop and the pto will stop turning, then your foot clutch is slipping. If the ground wheels stop turning and the pto keeps turning, then your hand clutch is slipping. You can use your brakes and a higher gear to conduct this test.
No smoke. the foot clutch is a dry clutch and will smoke, the hand clutch is a wet clutch(runs in oil) and will not smoke.
Edited by nella(Pa) - 01 Jun 2011 at 8:22am
crestline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crestline Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 7:32pm
My brother had a WD 45 with the same problem. Does your hand clutch "snap in" when you pull it back or is it soft and loose feeling? There are shimms in the hand clutch that you can remove after the plates have worn. When it is shimmed properly the hand clutch will be fairly hard to engage and will snap into place.
