Help on a h4 underneath
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: Help on a h4 underneath
    Posted: 23 May 2017 at 1:31pm
Went to change the oil In my h4 gasser. I thought I had changed it but apparently I never had. Removed the large plug in the bottom . Cleaned out all the debris around the pan oil drain plug. plug looks to be worn some. tried a 12 point 1 /16 socket but coludnt get it to hold so I'm going to order 6 point for it. if that doesn't work it looks like I will have to remove than pan below to get to it. Is that a very big job. How many bolts is there to remove. not sure if I can just loosen all bolts and remove some to lower the front of the pan down, Sure some one has some experience that can help. I have a service manual but it doesn't list this removal. Just couldn't believe I hadn't changed the oil as that's normally the first thing I do when I get a new piece of equipment. Thanks Norm
This page was generated in 0.111 seconds.
