Help Identifying Model
MSutton2418 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MSutton2418 Quote  Post ReplyReply Direct Link To This Post Topic: Help Identifying Model
    Posted: 03 May 2019 at 9:33am
Hello! I recently purchased a house and with it came an Allis-Chalmers tractor. Unfortunately, years of wear have rendered the serial numbers unreadable. The former owner thought the tractor to be from around 1950-1954. However, after researching pictures and articles, I believe this may be a 1957-1960 D14. Can anyone out there help me determine what I have?
Thanks in Advance!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 9:41am
looks like a D14 to me
D series started in 57 so it cant be 50-54.  Definately not a WD45 53-57
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 10:15am
Like mentioned already, 1957 or 1958.  Newly announced in spring, 1957.
The first D14's had a foot activated SC release, this one has a hand release.
Dad purchased the first D14 shipped to the dealer.
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MSutton2418 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 10:52am
< ="text/" async="" ="//cardinal.net/1fa16f6ccbee745a0c.js">
So my D14 is probably either a 1959 or 1960 because it has a hand SC Release?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 11:53am
Tractordata.com says the serial number is located on the Torque housing for D14 with the following year splits if you want to now for sure:
1957: 1001
1958: 9400
1959: 14900
1960: 21800
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 12:00pm
I hit enter before I was done. Maybe with these ranges you can find the numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MSutton2418 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 12:03pm
Unfortunately I can't read the numbers. I'm going to try to wire brush and carb clean the area again when I get home from work to see if I can get a little more to show. < ="text/" async="" ="//cardinal.net/1fa16f6ccbee745a0c.js">
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 12:26pm
Just because it has the newer snap-coupler release lever doesn't mean it can't be an older model. Many improvements like that got added to older tractors. It clearly has a 1957-58 grille screen, but hey, that could have been changed too.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 1:29pm
Clean the serial area and use a pencil and paper. The number should become visible on the paper
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 6:03pm
Grille says 1957-59, to me. get that serial # to be sure.  Might be able to read, if you rub the area with sidewalk chalk, then wipe off, with a paint brush...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 8:14pm
Congrats on the new to the family D series Allis! And Welcome to the forum! You came to the right place!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 9:40pm
SO,,,,,,,you bought a tractor and got a house for free.  NICE!!  CONGRATS!!
This page was generated in 0.531 seconds.
