Help identifying machine
jfriesenhahn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Topic: Help identifying machine
    Posted: 21 Apr 2018 at 7:45pm
Can anyone help me identify the model of this allis chalmers track loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 7:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 9:41pm
It is a h4,hd4 or 655 series if I remember right. Been setting a while. HTH Tracy
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:06pm
I do not see steering levers, so I am going to say 655.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:33pm
Welcome to forum. Is there a story with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 11:34pm
I thought it might be a 655 but I got an owners and service manual and some things look different. It has 3 pedals and 2 gear shifts, one between the pedals by the radiator and one under the seat. Also on the left side console by the seat I have a throttle lever and another blank spot that looks like it’s for the hydrostatic forward and reverse. but it’s not there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 12:16am
one between pedals at radiator must be the forward / reverse shuttle shift. one under seat is for transmission. I have seen hydraulic steering clutches next to the front of the seat on a 653.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:26am
Been sitting awhile. By the looks of the dirt fill in has been in water at least that deep a few times.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 9:41am
gas or diesel engine ?
seems the cage over the driver seat is something that needs work to be other than a brush guard or sun shade
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 3:07pm
4 cyl Diesel engine. I don’t think think the lever in between the peddles is the forward and reverse shuttle. It feels like it has more gears like a main transmission. I wish I had a picture of the operators station to show y’all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 4:20pm
the lever between peddles might be the fuel shut off that goes to injector pump ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfriesenhahn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 6:14pm
It’s not connected to the injector pump. It’ goes directly into the transmission. It’ looks like the machine has two transmissions and the main one is not directly connected to the engine. It has a driveshaft between the engine and the first transmission and then a driveshaft comes out of the first transmission and goes to the rear transmission under the seat. My other question is how do you turn the machine off? Is it with the throttle because I do not see any wires or any other cables on the injector pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 9:20pm
if the throttle will not then you should be able to cut off at injector pump. the previous owner may have an electric solenod wired in with key switch that will cut it off. they made a lot of modifications to this unit. more pics would help with identifying everything.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 6:03am
Unless this is a mix and match machine - the spoked front idler and the cover near the throttle control - operators left side  - indicates that the machine is an AC HD4.
The 650 series machines had solid front idlers, and no secondary cover near the throttle control.
With no steering levers ~ the machine might have had the optional pedal hydraulic steering.
Orangeman
This page was generated in 0.104 seconds.
