help identify large Zenith Carburetor
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Topic: help identify large Zenith Carburetor
    Posted: 20 Feb 2012 at 9:07pm
Took this on partial trade.  He said it was bolted up to his WD when he bought it, and it looked interesting to me.  The only numbers I can make out are 3795  Coule be soething before and coule be something after.  The fuel inlet is right over the ID tag, si a wrench must have smashed the tag and numbers.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 9:14pm
Zenith 124 1/2 top I do believe
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 9:27pm
Thanks. Also looks like i need to clean some keys on my keyboard!
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 9:28pm
Jim,
That appears to be a carb for an unstyled WC.  Are you selling?  Send me a PM.  Thanks
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 10:45pm
That's a Zenith 7078 dual fuel carb that came on the WC's for running Distillate or gasoline. The reason for the dual outlets......
Steve@B&B
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 11:30am
wc carb. just bought one for my 35
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 12:34pm
What's with the pipe plugs near the choke though?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 12:43pm
could of been one of the previous owners modifications.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 6:44am
I have a 7078 on the shelf that has the same plugs in it. Just part of the casting I would think...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 7:42am
I wonder what purpose they may have served? I've had quite a few 7078's over the years and had not seen this. There is one ebay with a bolt up flange for air cleaner connection. I hadn't seen that version either. It is listed as a 7178.
naylorbros View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote naylorbros Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 7:59am
I believe that the bolt up air cleaner flange carburetor is for the C CC early D and DC Case tractors.  That was my first reaction when I first looked at this carb until the air cleaner flange was missing.
Thanks
Ken
This page was generated in 0.056 seconds.
