help ID this trencher,,,, |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: help ID this trencher,,,,Posted: 21 Oct 2022 at 4:34pm |
OK, I've had this Ditch Witch C99 trencher for the longest and been stored in the barn for a few years. A friendly contractor had the engine completely overhauled for me and I only used it to dig a trench for a water line 4 or 5 years ago. I remember the dang carburator giving me fits back then,,,SO, I want to order a replacement carburator for the engine. It now has an updraft carb but I ain't found one on Ebay or amazon,,,plenty of side draft carbs but no UPdrafts,,,,?? I'm thinking the engine is a Wisconsin single cylinder with numbers on tag==AENLD-2--- 408004--5909185--- Tag on the trencher frame is C99---SN113107 It would NOT be a big issue to build a different "intake" to use a newer side draft carb which are a dime a dozen on Ebay ($22) I got some pics to see if someone can ID the carburator,,,,,,
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 21 Oct 2022 at 5:45pm |
DJ... use Google " AENLD-2" you'll get a zillion 'hits'..... Jay
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 22 Oct 2022 at 12:50pm |
Darnit, Joe- If you wanna us to identify the CARBEURATOR... then git in there and post a picture of the CARBEURATOR... from that angle and distance, it could be ANYTHING... Zenith, Tillotson, Marvel Schebler, Bendix... Good thing it has a starter-generator on it, my buddy has one of those trenchers on steel tracks... rope start.
desertjoe
Posted: 22 Oct 2022 at 10:35pm |
Chit Dave,,,ole Buddy,,,ole pal,,,,,, ![]() ![]() I WAS SOME PRE-MATURE ON THIS ONE AS i AM GOING TO REMOVE IT TAMARROW,,, ![]() I have bad memories with that carb as it was always tempermental SOB even after a complete clean out and new carb kit The contractor told me that he put a kit in it also,,,!!! I'm thinkin bout machining two plates with the bolt pattern of the intake but with a straight 1" nipple welded between the two flanges to mount a carb that is NOT an updraft I did find some "NEW" rooskie made carbs on Ebay that are listed for the Ferguson TO 20 tractors,,,,reckon one of them would work,,?? That starter is also a generator and is 12 volt and works many wonderfuls
shameless dude
Posted: 23 Oct 2022 at 2:42am |
gits you another engine for it....a more modern one!
desertjoe
Posted: 23 Oct 2022 at 7:49am |
Well, CHIT,,,,and,,,,and,,,I thought he was my buddy,,,,,,
