Help ID a B |
tmiller
Joined: 11 Oct 2010 Location: Waynesburg PA Points: 82 |
Topic: Help ID a BPosted: 14 Sep 2012 at 7:57pm |
Of course when I wanna put pics up the computer has to play dumb but met a guy today who has a B and he was wondering acouple things, it has spoked front wheels, a rear view morror that says Allis Chalmers and fenders that seem to cover the tires. He thinks its a aircraft plane that pulled them during wartime but im not sure. Any ideas? Also has front weights that mount on the axel, would they be orgional?
Thanks Taylor |
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 14 Sep 2012 at 8:12pm |
Steel wheel B on rubber, w cut down fronts.
The weights maybe original, the mirror, not..... |
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 14 Sep 2012 at 10:28pm |
The wide fenders were used on the steel wheeled tractors and the spokes on the front were steel wheels that were cut down and a rim welded for rubber tires. The front weight was an option, but I don't think the mirror was original. The serial # will probably put it at about 1943- 45. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 18 Sep 2012 at 4:31pm |
Year sounds right. After WWII we usually put new wheels on front but if you did it right you could use the spokes.
Good Luck! Bill Long |
