Help ID a B
tmiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmiller Quote  Post ReplyReply Direct Link To This Post Topic: Help ID a B
    Posted: 14 Sep 2012 at 7:57pm
Of course when I wanna put pics up the computer has to play dumb but met a guy today who has a B and he was wondering acouple things, it has spoked front wheels, a rear view morror that says Allis Chalmers and fenders that seem to cover the tires.  He thinks its a aircraft plane that pulled them during wartime but im not sure. Any ideas?  Also has front weights that mount on the axel, would they be orgional?
Thanks
Taylor
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2012 at 8:12pm
Steel wheel B on rubber, w cut down fronts.
The weights maybe original, the mirror, not.....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2012 at 10:28pm
The wide fenders were used on the steel wheeled tractors and the spokes on the front were steel wheels that were cut down and a rim welded  for rubber tires. The front weight was an option, but I don't think the mirror was original. The serial # will probably put it at about 1943- 45. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 4:31pm
Year sounds right. After WWII we usually put new wheels on front but if you did it right you could use the spokes.
Good Luck!
Bill Long
