help gleaner E in corn
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:02pm
If you don't have a 35 or 44 tooth sprocket, leave it in the shed or quit complaining about cracked corn. If the combine isn't properly equipped it can't work right.
How does that reply help me? If it is impossible for you to help with the situation I am in now, I demand that you stop posting unhelpful and negative comments. Those comments are not worth the time it takes to read them.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:07pm
Tried a bit today at 1/3 to 1/2 throttle. Still getting cracked kernels in the bin. Corn is at 16% moisture. Tomorrow I will get a 44t sprocket and try that. Hopefully it will work.
www.awtractor.com
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 4:55am
Doc can sometimes come across as "testy", but his reply here was actually good advice. If you look at Steve, Mack, and Docs replies just before this as all together, they are good points. I know it can be frustrating, and sometimes easy to feel insulted, but I don't think that was anyone's main intent here.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:52am
I agree with Tbone, take the doc's advise. It'll get you further than guessing. Cutting your throttle back like you tried was well.... let's just say inexperienced of you. Take your time, make sure your have the parts installed as people have already told you. You just can't make a combine equipped with small grain sprocket perform as it should in corn. It's just one of those things. It's like trying to defy gravity. BTW are your cylinder bars worn of do they have a square edge yet? Worn bars will make it a grinder too but it doesn't matter until you get that cylinder slowed down with a larger sprocket. I used a 44 tooth back when I combined with my E and it worked real good.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 10:40pm
     Because of my inexperience, I ask for help on this forum. If I were to take the advice about leaving my combine in the shed: a. I would not gain any experience and b. My corn would not get harvested. Both are contradictory to what I need to accomplish.
    I got a 42 tooth sprocket and had it bored out to fit the hub today with the holes drilled. I have a lot less cracked corn. Only 10% to 15% cracked now. Corn is at 15% moisture. Lonn- The cylinder bars are round, not square. I'm guessing that is certainly not helping me. It does leave a few kernels on a cob once in a while, but it wil get me through this year.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 10:48pm
If you look back to the replies (from experienced people)you got from Nov 5th thru Nov 7th it was pretty clear that a different sprocket was needed. I'm glad you finally gave it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 9:11pm
Lonn,you better define square because they are not technically
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 9:53pm
Finished my 10 acres this evening, thanks for all the help guys! I couldn't have done it without you Big smile
www.awtractor.com
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 8:02am
You're right. I believe the book gives a good example drawing as to what I'm referring to as square.
I'll look for a picture to post. Dad's old E was just plain worn out and the bars were particularly worn badly. We couldn't get a nice sample no matter what. Then I bought a very nice E. The elevator crew knew right away we had done something different. They actually thought we'd picked up a rotary but I told them, no, just another E but in good shape. The one guy named Norm said our sample was as good as any new combine. That was back in the late 1980's.
Here, in this pic, you can compare the leading edge which is rounded and the back edge which is still square (or if you prefer .... sharp). These bars in this shape shoupld probably be reversed so the new edge can do the threshing.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 1:38pm
Yes, mine are worn like that.
www.awtractor.com
