Help finding mark on governor gear |
Post Reply |
Goose
Orange Level Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Posted: 25 Jul 2021 at 10:06am |
Hello everyone,
I am having trouble recognizing the mark on the governor gear that matches up with the cam gear. Reading the service manual, there's supposed to be an oval mark somewhere, but I'm not finding it. It's on a 1948 AC C engine. |
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 943 |
Thanks(1)
Bottom tooth of gear when I zoom in on pic?
DaveSB
Silver Level Joined: 04 Aug 2012 Location: mocksville, nc Points: 235 |
Thanks(1)
Yes, it looks like bottom tooth on gear.
Just make sure with piston at TDC compression stroke, the magneto drive lugs are horizontal and you will be fine. |
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Goose
Never mind. Thank you for all your help.
I found it. Like a dummy, I was searching on the wrong side of the gear. It is on the opposite side and is very apparent. No problems! Thank you! |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2592 |
Thanks(1)
Hey Goose check out this page. Don't know if it will help you but it did me. http://rodnh.byethost12.com/acb/magtiming/magtiming.htm
Goose
Thank you!
I keep seeing that the #1 post is at 10 o'clock when the fire mark is near on the flywheel. For some reason, mine is at 2 o'clock. The rotor at 2 o'clock, where the #1 spark plug wire is attached on the cap. The only problem is that it's a little early. The piston on #1 is still about a couple inches before TDC. I don't know if someone before me messed it up, but it was running until I tore it down for an engine rebuild.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77620 |
Thanks(1)
They mark everything to make installation easy.. you can put it together wrong, and put the plug wires on the wrong terminals in the end..... as long as it FIRES on #1 wire when that piston is at TDC.
Post Reply | |
