Help: d12 series 3 Hydrolic issues
allis1221G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Topic: Help: d12 series 3 Hydrolic issues
    Posted: 28 Dec 2021 at 2:53pm
Ive got a 67 d12 series 3 that im have troubles with. Wondering if anybody has experienced low hydrolic pressure to the 3 pt and rear outlets. At 1600 rpm im only getting 1100 psi of hydrolic pressure at the outlets and 3 pt makeing it difficult to lift implements. Wondering if anybody can lead me in the right direction as to what the problem could be. I have tried adjusting the inlet releif velve on the spool velve with no change and also tried a different hydrolic pump with same resaults. My other series 3 has 1850 psi at an idol so im running out of options. Any help is greatly appreciated thanks
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 2:40am
Does the PTO run an implement like a mower OK? Any unusual noise in the clutch area?
This page was generated in 0.258 seconds.
