Help 8050 hard steering
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Help 8050 hard steering
    Posted: 23 Sep 2023 at 7:33am
I’m had this tractor 3-4 years it’s been harder to steer the most of the time I’ve owned it. Been bad enough twice were I’ve had to use brakes to steer. First time old school Allis mechanic pulled the priority valve and cleaned it a got me going. Second time I did it. It now is currently steerable but takes EFFORT. It had some other issues to so it landed at the Agco dealership(was Allis back in the day). The tech that got assigned to it admits he’s new to working on tractors but sounds fairly mechanically inclined. He agrees it steers hard. He’s checked the priority valve, checked flows and pressures. He has changed filters it’s no better. He admits he’s at a loss where to look next. Flows and pressures are good. I told him I’d do some research over the weekend and get back with him.
Ideas?
Something in the steering column? He has the front end up on blocks and still stubborn.
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 8:04am
If it is a FWA, the axle u-joints could be dry and trying to seize. If you have it jacked up, unhook one end of the steering cylinder and use a pry bar between the tire and spindle and try to turn the wheels. New u-joints made my 8070 steer like new.
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 8:05am
Take the steering cylinder loose on one end and see if you have the same results
That will tell ya for sure if you have a hydraulic issue or a binding issue in the front end
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 8:06am
Two wheel drive or FWA?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 8:49pm
Make sure the office didn't get lost during one of the checks.                 MACK
