HELP!!! 616
Jon C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon C Quote  Post ReplyReply Direct Link To This Post Topic: HELP!!! 616
    Posted: 11 May 2014 at 5:13pm
Where can i find info/diagrams for removing the onan 16.5 HP in my Allis 616 tractor.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 6:08pm
Not much to it , remove lower bolts from under side , lift up after also removing the drive pulleys , of course you need to remove wiring, fuel line , choke and throttle attachments
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon C Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 7:28pm
Wow it looks much more complicated.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 12:44pm
A easy job once you remove the 4 bolts holding the engine to the frame - but removing the drive pulley shaft sometimes can be a problem - take it slow and just document things if this is your first time going this deep .
 The wonders of a digital camera can come into play to jog memory when putting it back together .
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 5:58pm
I just took a blown up B & S 16.5 out of my 516-h, and the hard part is putting an engine back in! LOL!!! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon C Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2014 at 4:27pm
I just received the tractor manual in the mail so it should makes the process easier. The digital does help. Thanks for the advice.
This page was generated in 0.135 seconds.
