Headlights for HD16DC
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Headlights for HD16DC
    Posted: 23 Aug 2017 at 8:39pm
Hello group.
Question I have is regarding adding headlights. My HD16DC is getting cleaned up and brought back to specs. My 16 has the headlight covers in the front grill. Are they difficult to put lights in? Wiring and brackets source?
Thank you
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 11:02pm
Originally posted by jerbob jerbob wrote:
Hello group.
Thank you
Have you consulted the shop manual yet? There are no sources for  OEM parts for this. You'll probably have to improvise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 6:34am
Just remember this is 24V start/charge as well. The charging system has to be functional to utilize lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 6:40am
[QUOTE=DMiller] Just remember this is 24V start/charge as well. The charging system has to be functional to utilize lights.[/QUOTE
Thank you. You are correct and I did not take into consideration the 24 volt aspect of the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 7:24am
You can run 12 volt lights if you tap into one of the two batteries. I'm adding lights, a cab fan and radio to mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 7:32am
Glad you jumped in on this doctorcory. That saved me from making that my next question. I was thinking same thing. The parts manual shows it tied in at the dash light switch along with a rear floodlight option. I will cut in both. I have full instruments and dash light on my 16. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 7:53am
Careful with that as you run the risk of bypassing the cutoff switch, could end up with One dead battery where get low voltage and cook the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:00am
Thank you DMiller.
My 16 does not have the original battery cut off switch. One of the previous owners, I suspect the last owner did it. As another topic, should I replace that battery cut off switch? Currently batteries are wired to each other without that cut off switch. I was curious about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:02am
Thank you DMiller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:06am
Thankbyou very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:07am
I replaced mine as that gave me a positive cutoff should I get a short in a cable or starter hangs in. There is only one other alternative, hacking a cable to stop destruction in that type event, also slows anyone wanting to 'joyride'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:21am
Good Idea. The previous owner upon my first inspection of the machine, when I asked where the cut off was he said he took it out but could not recall why. Never put it back in. His hack was to switch out the battery cable and battery to a top post bolt screw and not a traditional battery cable clamp. he would disconnect the + cable end on the one battery to be sure to eliminate any shorts or draws on the battery.
I want, when completed, to have a original machine with all parts repaired and replaced. The battery cable ends are junk anyway and all rusted and need to be replaced regardless.
This page was generated in 0.263 seconds.
