head gasket sealer
Message Reverse Sort Order
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Topic: head gasket sealer
    Posted: 04 Nov 2016 at 7:34am
Hylomar is the best I've seen. Sounds like you need to have seal tec make you a solid stainless steel head gasket, along with their fire rings.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 8:06pm
just wondering what is the latest and greatest head gasket sealer. i am running 350 psi compression in my wd 45. haappedwr upve to reseal once a year. i have new copper head gasket and have used windsheild sealent in the past and last time used hylomar, had small water leak between 1 and 2. want to get it sealed up
phil
