Head Gasket Rules ?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: Head Gasket Rules ?
    Posted: 27 Nov 2010 at 7:03am
What are the guide lines for head gaskets. I have installed them and for one reason or another had to remove the head again. Is there a limit of how many times you should torque down a head gasket. What is the time factor - Older engines always get a new gasket if the head is removed - What about recent overhauls of 2 - 3 years.
Heard of people spraying with silver paint - only on used gaskets ? Why silver ? Never add any sealer to prevent water or compression leaks ?? Or is some sealer better than others ?
Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:37am
My own personal preference (WC-WD-WD45-D17-170-175) is to rub a very thin layer of RTV silicone around all water passage holes and all around the O.D. 1/4" of the entire  head gasket on both sides, so the RTV seals all water from seeping and no oil can seep on the pushrod side. Also the two gaskets on top of the head for the thermostat hsg and a cover plate I never use (because they sometimes squish out), just use RTV. I prefer orange, gold or red RTV. Retorque head bolts COLD after engine has been run for a time (after a dyno run is good) and reset tappets. Head bolt holes must be clean in the block and bolt threads must be lubed with grease or oil so they aren't dry. If your concern is a WD45, D15, D17 or D19 diesel, they are junk and can't usually be fixed without spending a lot of $$$$$$....poor sleeve lip design (or I should say no lip to hold the sleeve "up").
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 8:25am
Back years ago silver paint was used to be able to reuse the head gasket. Some how it was thought that it was a sealer rather than a anti seize. When a head gasket does not stick fast it can and was reused buy some. When I was pulling every weekend I have pulled the head and reused the gasket if it had not stuck without any problems. I have never used the silver paint which is paint with fine aluminum particles. Aluminum anti seize just has more aluminum particles and grease of some kind.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:18am
When Ford came out with the high compression 312 interceptor engine they recommended painting both sides of the head gasket with aluminum paint, letting it dry and then painting both sidea again and assemble when wet.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 10:27am
Some gasket makers want it torqued onces, not retorqued. Some like it torqued twice the second one are running a while. Not all head gaskets are made alike and need to be treated alike.
Gerald J.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 10:43am
follow the gasket mfg recomondations, I used silver paint for long time on the steel gaskets that had the ridge stamped in them , on composition gaskets it called for sealer I use copper coat now. Fel-Pro gaskets were pre treated for a long time and said not to use any material on them.
 On other gaskets I have used grease, copper-coat, and also RTV gold or red depending on heat. trick to RTV is thin layer (next to nothing) let skin then install.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 11:13am
For me it depends on gasket type and material. Most Fel-Pro head gaskets are teflon coated. On those, I install dry. If it is a metal or metal clad type, I use Copper Coat on them. Late model multi layer metal go in dry. Old engines like tractors get retorqued. New stuff doesn't.
Technically speaking, a head gasket is not reuseable. They take a crush only once. I haven't tried to reuse one, but I have heard many say they paint them and reuse without any problems. Your mileage may vary...
