Head bolt recommendations
pungobob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Topic: Head bolt recommendations
    Posted: 06 Apr 2023 at 5:41pm
Well I got extremely lucky and only broke four of the head bolts on my G. Now I need some help from the G gurus here on the forum. The bolts I was able to remove are badly corroded and will not be going back in my engine. My question: what is the best bolt material should I use to replace  the bolts? Grade 8, stainless steel? Any recommendations will be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 5:43pm
i bought a disassemble "B" motor 20 years ago... had no head bolts.. I just bought grade 8 steel bolts and put it together.... 20 years ago.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 6:47pm
Not stainless.  They are softer than most realize and threads gall easily.  Use Grade 8
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 8:08pm
Thanks Jim and Steve. I was in the marine industry for a lot of years and completely understand the galling tendency with stainless. Grade 8 it is. Thanks again for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 6:38am
Run a bottoming tap down each and every head bolt hole in the block. Rinse/wash out with brake kleen and use compressed air to blow out remaining any dirt. Wipe grease lightly on new head bolt threads for lube. Torque to spec. Retorque after a few hours of running time when engine is stone cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pungobob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2023 at 7:07am
Thanks for the reply Dr Allis. I have got the bottom taps on hand. Waiting on my torch tanks to get filled so I get heat up a couple of the broken off bolts and studs to facilitate getting the head off. No need to get in a hurry.
This page was generated in 0.219 seconds.
