HD-9 loader, any good?
stoneridge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stoneridge Quote  Post ReplyReply Direct Link To This Post Topic: HD-9 loader, any good?
    Posted: 13 Jul 2016 at 11:44am
looking at an HD-9 loader and was wondering what they are like as far as parts availability and overall durability.
I was planning on using it around the farm to clear fence lines etc, not any real heavy work.
Has Detroit engine and bucket, claims to have 80% undercarriage and new clutch+ pressure plate. Tin and Bucket looks straight.
Have only seen pics and plan on going to see it in person. What should I look for and are there any red flags that I should be aware of.
Any idea of value if it's decent?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 12:06pm
detroit engine is actually a plus as they are easier to get parts for than an allis engine.  if the undercarriage is good i would say go for it.  i have not owned a track loader but i would sure be checking the undercarriage and truck frames they take alot of abuse on a loader turning under weight
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 7:30pm
2X what Cal said.
R.KYLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.KYLE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 9:08pm
I HAVE AN HD9B DOZER WITH 471 DETROIT. GREAT TRACTOR.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 9:46pm
I have a HD-9G loader that I have loaded a 10,000 lb. flywheel onto a trailer. good machine to play with.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 11:42pm
Norm, what does a 10,000 lb flywheel fit???
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 10:24pm
That flywheel part was 1 of 12 pieces to make complete 25ft.4in. dia. flywheel with total weight of 60 ton. It is on a stationary steam engine that I operate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stoneridge Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 8:40am
Had a look at loader and looks really good for it's age.
some loose in the loader mounting brackets and bushings but nothing I didn't expect.
Are there wedges of some kind that tighten the brackets to the frame? Looks like there is a gap between bottom of bracket and crossmember that holds the bracket at bottom. Or is it just bolted tight?
engine sounds really good.
Had trouble with the linkage/lock when shifting from low to high range. had to lift on the rod that goes under floor to slip it into high but once in gear seemed to be fine. Is this a big concern or tough fix?
under carriage looks good,rails in good shape and sprockets good.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 3:35pm
The HD9 is a good machine and you could check the frame bolting to the stering rear housing sometime the bolts are broken and the frame could be loosed from stering cluch housing
This page was generated in 0.438 seconds.
